Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Stock steering column and rack, anyone?
Old Jan 26, 2021 | 08:13 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Does anyone have a stock steering column (double D shaft) and going to a rack? (3/4" shaft)
Have any pics?
Did you use 2 or 3 u-joints?
Old Jan 29, 2021 | 10:40 AM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Re: Stock steering column and rack, anyone?
This is the kit that I got from Racecraft
The 1st pic, the u-joint is hooked to the rack, then to the 3/4" hollow shaft.
It's looking like I need a 3rd u-joint and a heim joint, to stabilize the shaft, to get the proper angles to go around the headers.
Time to fab more stuff....
Old Mar 17, 2021 | 08:17 AM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
I have the steering shaft almost done
Had to cut off the end of the stock column, then put in the coupler to attach to the 3/4" smooth u-joint.
Here is it, in place, just have to finish welding the shaft up.
Here is the plate to get welded to the frame, so that it will hold the rod end, to keep the shaft in place
Old Mar 17, 2021 | 11:08 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Can you add a couple of shots of the rack itself?
Old Mar 17, 2021 | 10:07 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Ok, I'll try to crawl under the car tomorrow after work
Old Mar 30, 2021 | 01:53 PM
soloc4's Avatar
Car: 84 Z28, 92 C4 suspension F&R, ABS
Engine: 408 LS2, CNC LS3 heads, Comp Cam
Transmission: Magnum F, RTX clutch, Tick shifter
Axle/Gears: DANA 44, Tru Trac, 3:73 gears
Mute point at this time for you, but this is what I did.
Old Apr 4, 2021 | 07:35 PM
micktroup's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7L V8
Transmission: auto
That’s some slick fabricatin’...
Old Aug 29, 2022 | 11:07 AM
Beeman's Avatar
I'm just getting around to preparing to install my rack. I have double D style shafts and Flaming River rack and 2 universal joints and a support heim.. What I'm lacking is the universal joint that you used at the column. Where did you get that joint? It looks like it's got a number on it but I can't see all of it. I'm wanting to attach to my column and use my double D style shafts.
Old Aug 29, 2022 | 12:00 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
I got all stuff from RaceCraft.
This is what I used
https://www.racecraft.com/steering-s...mn-p-1449.html
They recommended this for more street driving
They also have this for more strictly drag racing applications
https://www.racecraft.com/steering-s...umn-p-334.html
Old Aug 29, 2022 | 02:12 PM
Beeman's Avatar
thanks for the links. I see the kits require cutting the column and then sliding that piece in the tube. I've messaged Flaming River and from what I understand there is a joint with a 1" double D that will slide up on the factory column end without cutting it. One of the 3/4" double D shafts I have is drilled through and I believe it will slide up into the end of the factory column if you didn't want to use a u-joint. I prefer a joint at the column like you used and I have the heim for the support.
Old Sep 2, 2022 | 09:45 AM
Beeman's Avatar
I messaged Racecraft and they recommended the joint you have which requires cutting the bottom of the column shaft. I also messaged Borgeson and Flaming River and they say the 1" Double D Joint will fit the column without cutting. I do like the Racecraft setup with the piece that slides inside the column. I think I can do the same with a piece of 3/4" Double D shaft inside the column and use the 1" Double D that slides up on the existing shaft without cutting.
Nighthawkf-117
Apr 25, 2015 12:35 PM
IROC-J28
Apr 18, 2009 01:31 PM
Wadebryant
Sep 27, 2007 07:46 AM
MILT
Apr 13, 2002 03:47 PM
