FAQ Board This board is where some of the most informative and helpful Frequently Asked Questions we get here at ThirdGen.Org are put for easier reference. This IS NOT a general question board.
power steering brackets
Old Apr 18, 2004 | 12:09 PM
madvikefan's Avatar
Car: 85 transam
I am having trouble attaching the 82 Camaro's power steering pump to my 350 engine! The engine used to have factory exhaust manifolds of which I replaced with Hooker Headers and now I am finding that the Power Steering brackets are not fitting right. Apparently the factory manifolds had longer bolts and extended out futher and were designed to allow the PS Pump bracket attach to the 1st bolt on the manifold. Did I do something wrong??
Old Apr 18, 2004 | 05:39 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
The 'problem' is that the original manifold had a thick mounting flange; 1" or 1¼" or so thick, compared to a 3/16" or so thick header flange.
One solution is to use a stud about 2½" long to fit into the bolt hole in the head, use a nut to hold the header flange tight, then use two more nuts to space out the PS bracket where it needs to fit...one nut on each side, and jam them together.
Old Apr 18, 2004 | 07:45 PM
madvikefan's Avatar
Car: 85 transam
Thanks!
Can't wait to try it!
The wife has a "honey do" list before I try it though!
It won't take long, I'll do what I usually do... lose
the list after finishing the first request!
Old May 11, 2004 | 07:10 PM
yzarcem's Avatar
Car: 82 Camaro; in process of resto
Engine: 350 4bbl.
Transmission: 700R4 with B&M Lockup
Axle/Gears: Moser 28-spline axle; 3.23 gears
I have the same problem...and if you look at the exhaust manifold, you'll see exactly what Petes 84Z28 was talking about--it puts the bracket much farther from the engine compared to what the header will do for you.
If you look at your PS Pulley from the passenger side, do you see it tilited out of plane with the rest of the pulleys?
Check out Summit...MCH-20165. This should solve the problem. As soon as I finish my wife's honey-do list, I'll order one & slip it on. Right now, I let mine ride. It is a belt-eater over time, but it will run.
Old Jun 22, 2004 | 11:52 AM
yzarcem's Avatar
Engine: 350 4bbl.
Well...the March kit would work, if you wanted to sacrifice your AC. I had to return the kit. I modified my old bracket to make it work.
Here is an alternative, though:
http://www.spohn.net/product.cfm?productid=1460
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
evilstuie
Apr 14, 2016 08:52 PM
Genopsyde
Nov 11, 2015 10:46 PM
