FAQ Board This board is where some of the most informative and helpful Frequently Asked Questions we get here at ThirdGen.Org are put for easier reference. This IS NOT a general question board.
Easy ramair for thirdgen camaro tpi
Old Dec 1, 2005 | 09:48 PM
firebirdowner89's Avatar
Car: 89firebird
Engine: 355 TPI
Transmission: world class T-5
Axle/Gears: 3.73 posi
This is a free ram air for your thirdgen camaro with TPI and its very simple and no parts are needed. It will take probably 20-30 min. to do and it realy works.
First take off the air cleaner top, then the air filters. Then take off the peice that holds the filters, and in the center of the squares is a plastic bar that runs across cut those out for better flow if u want. Then below that u will see the fog light wells down below cut a square out of each one 3-4 inches and across , cut them so the air coming into the fog light well will flow though and up into the air cleaner. This is a pretty cool idea and we tryed it and it does work. if any one has any questions just ask..
Old Jan 29, 2006 | 02:23 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
done this myself.you must be careful in heavy rain, your air filters will get soaked.
Old Mar 19, 2006 | 09:36 PM
89_fireform's Avatar
Car: 89 WS6 formula firebird
Engine: 305 TPI :(
wat squares?
Old Mar 20, 2006 | 09:20 PM
Car: 89firebird
Engine: 355 TPI
First thing this only works on the thirdgen Camaro because of the fog lights. The squares are wat u have to cut out to make the fog light wells direct air up to the air filters...so it comes through the fog light then up to the air filter and so on....
Frozer!!!
Jan 19, 2024 04:55 PM
MantyZ28
16
Dec 21, 2015 11:02 AM
NBrehm
Aug 25, 2015 11:49 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
