FAQ Board This board is where some of the most informative and helpful Frequently Asked Questions we get here at ThirdGen.Org are put for easier reference. This IS NOT a general question board.
305 vortec heads on 350
Old Sep 13, 2006 | 01:38 AM
firebirdowner89's Avatar
Car: 89firebird
Engine: 355 TPI
Transmission: world class T-5
Axle/Gears: 3.73 posi
i need some help......im building a 89 350 with flat top pistons with 4 valve relive. and and i have a 89 305 with vortec heads can i use my 305 heads on my 350 im going to use a mild roller cam also......please give me some tips...
Old Sep 13, 2006 | 02:30 AM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
i would not use these heads for a few reasons
1.58 cc head will run your compression up
2.this head although it is a vortec design will not flow for crap due to the small valves.
3.you will have to buy the vortec intake and put them on these heads
4. you will not feel the benefit of a performance cam without the flow from the head.
you would be better off having tpi heads(5.7) if money is an issue
Old Sep 19, 2006 | 01:03 PM
Car: 89firebird
Engine: 355 TPI
ok thanks man
Old Sep 21, 2006 | 06:46 AM
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
The L31 350 head is much better than the 305 version.
It has 64cc chambers. If you port the exhaust side some, they make gobs of power. You will have to use a special intake though.
And also, tune, tune, tune.
The rewards should make it worth while.
Ron
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
