FAQ Building Board This isn't a "question" board. This board is where we all can figure out what we need added/changed to the FAQ on thirdgen.org.
Question about torque arm/pinion angle
Old Oct 18, 2003 | 09:37 PM
TTA850's Avatar
Car: 2013 C63C
Engine: M156 (P31)
Transmission: 7 speed MCT
Axle/Gears: AMG Limited Slip
I'm using a Jegster torque arm(real short one that bolts to the body rather than the trans) with Hotchkis arms and panhard rod(non adjustable) riding on stock springs w/air bags(25#r/s,5#l/s)and KYB shocks.
Anyway,I'm happy with how the cars performing - at 3,530lbs with 3.08 gears on 26x11.5x16 ET Streets on stock rims I've gotten 1.49 60ft with consistant 1.51's.
What I wonder is what my pinion angle would be with the suspension components I've used so far.And would it be worth while going to some adjustable parts?I'm already planning on helping my short times by going with full slicks and 3.42 gears for next year just looking into other options.
Thanks in advance,
Steve
Old Oct 19, 2003 | 08:48 AM
ede's Avatar
ede
unless you want a guess that means nothing the only way to know the angle is to get under the car and check it. you can change it, but permanetly, by using relocation brackets for the rear control arms instead of replacing parts you've already bought
Old Oct 19, 2003 | 10:53 AM
TTA850's Avatar
Car: 2013 C63C
Engine: M156 (P31)
I already have relocation brackets.
Not to sound like an idiot but how do you check pinion angle and what not?Suspensions always been something I never really understood and any insight here would be greatly appreciated.
Steve
Old Oct 19, 2003 | 12:23 PM
ede's Avatar
ede
pretty sure steve has a how to on his site if not try a search ehre or sethirdgen.org. pinion angle should of been set when you did the relocation brackets
Old Oct 19, 2003 | 12:44 PM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
Here's a drawn I have skecthed and save specifically for everytime this topic comes up.
Attached Thumbnails Question about torque arm/pinion angle-pinion-angle.jpg
Old Oct 19, 2003 | 12:47 PM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Heres some reference examples based on different car ride heights- set the angle on a stock height car, then lower the car, and the angle will be wrong- it needs to be set at ride height.
Attached Thumbnails Question about torque arm/pinion angle-pinion-angle-2.jpg
84z96L31vortec
Aug 20, 2017 12:16 AM
87iroctheo
Dec 4, 2016 11:47 AM
91REDZ28VERT
Fabrication
Sep 3, 2015 02:28 AM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
