FAQ Building Board This isn't a "question" board. This board is where we all can figure out what we need added/changed to the FAQ on thirdgen.org.
How do I get positraction?
Old May 18, 2000 | 12:46 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Q: How do I get positraction for my open rear end?
A: If you have an 89-92 car with 28 spline axles, get the $99 SLP take-off posi unit, and a set of 3.23, 3.42, or 3.73 gears, and have a skilled rear-end installer install it for you. If you have an 82-88 car with 26 spline axles, you will also need the 28 spline axles from an 89-92 car, or aftermarket axles from Moser or another company. You could also just swap the whole rear end from another car.
1991 Camaro Z28
5.7L 5-Speed
13.32 @ 105.27 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
Webmaster: ICON Motorsports
Old May 18, 2000 | 07:37 PM
84ZZ4's Avatar
Slight addition:
If you currently have 3.23 or numerically higher gears, your current gears will fit the take off carrier.
Old May 19, 2000 | 12:21 PM
Kevin91Z's Avatar
You're right... I figured more 3.23 or higher cars already have posi, and this was for the 2.73 owners.
Also, what if you have the 7.5" ring gear, instead of the later 7.625" ring gear? Will the 7.5" gears fit the later posi?
Old May 19, 2000 | 04:03 PM
84ZZ4's Avatar
Yes, they will... just did it.
I do NOT know if the 7 5/8" GEARS will fit a 7 1/2" posi. My gut feeling is, no, because the gap is on the inside diameter.
IOW, the 7 1/2" gear on a 7 5/8" posi leaves about 1/8" empty space between it and the carrier.
And, BTW, almost all early T5 cars got 3.42 gears... and posi was an option, most of them didn't have it. A lot of open 3.42 drum rears floating around , including one sitting in my back yard.
[This message has been edited by 84ZZ4 (edited May 19, 2000).]
my82roc
Aug 4, 2004 09:51 PM
Oddball
Dec 29, 2003 06:25 PM
89Rock
Feb 22, 2003 08:57 AM
elevario
Mar 26, 2001 07:44 PM
BLUE92RS
Oct 11, 2000 10:59 PM
