[OH] 1991 Formula T-Tops - Lots of New Parts!
I have a 1991 formula 305tpi, disc rear end with 3.73 richmonds. 5spd.
Brand new magnaflow catback, Dyno Don's headers with ceramic coating on inside too (per request) & Y-pipe, Founder's Performance LCA & Panhard bar, aluminum driveshaft, all new hoses, brake lines, brake hardware, radiator, heater core, and most other parts that are subject to wear. I bought a lot of parts, and never put them on, or they were put on, but never got the car back together since then. Was originally a 2.73 drum, automatic.
I have new waterpump, oil pan, flywheel & clutch, clutch slave & master cylinder, plus others. Even e-brake cables, wheel bearings...I was kinda OCD about replacing everything I could, so theres a lot of new parts.
After I bought the driveshaft, rear end, and 5 speed I had them all checked out.
The 5 speed has new seal, the driveshaft has new u-joints and is balanced, and the rear end was looked over and new seals put in.
Everything is in place for conversion. (Pedals installed, Dakota Digital - to correct the speedometer for new gearing, 5 speed shift boot, proportioning valve installed for disc brakes, etc...)
Rear end, WC T5, and aluminum driveshaft are from 91 camaro.
The engine hasn’t been touched. It ran fine, but you can tell there are a couple seals/gaskets that leaked a little oil. I’ve been told it’s “typical gm” around the valve covers, but regardless, I did have plans to get it rebuilt while it was out.
I bought the car, drove it for one day, and parked it. I took it apart with intentions to upgrade it and replace most every part, whether it needed it or not, so when I was done, I'd have something "100% new" I could drive across country with no worries.
Mid-way through this project, I had shoulder surgery, then kitchen remodel, house projects, etc...
It's been setting in my garage on concrete floor for 5 years that I've owned it.
102,000 miles. I have a clear title.
NO RUST!
I'm located in Washington Court House, Ohio
(50 min. south of Columbus)
With all the new unused parts and condition of vehicle I’m asking $3,500.
You can pm or call/text at 937-205-8475 with any questions.
It currently sets as a partially completed project.
NO RUST!
Re: 1991 Formula T-Tops - Lots of New Parts!
This has wheels and tires on it and can be rolled into a trailer.The engine and transmission are removed, otherwise it’s all together I’m open to reasonable offers or suggestions for this sale[/left]
9manastacio
07-22-2014 05:54 AM
BlueZee28
Mid-West Region
06-02-2010 06:25 PM
JB22
03-22-2008 07:30 PM
