[GA] SOLD
Car: 1989 Formula
Engine: 355ci HSR SBC
SOLD
Long story short. Got hurt on the job and the car has been sitting for 3 years. Had a built motor but I sold the heads and stealth ram/injectors off of it.
SBC 350 4 bolt Block from a suburban/Tahoe with hypereutectic pistons. Comp Cams 268XFI. Been sitting outside.
Transmission from a Pickup with a 500hp 383. (1991 700R4)
GM Edge 3000rpm stall converter.
Factory 9 bolt posi trac rear.
Factory Disc front and rear
Interior serviceable, but not great. dash cracked, not terribly, but in the middle.
Wing dry rotted.
Tires ok, some dry rot but they hold air.
no problematic rust, surface.
Hood rough.
Headlight motors inop.
I have the OEM intake and heads in storage but the iron heads are pretty rusty.
It's rough all around.
I figured I would post it here and hope someone wants to save it. I will post more pictures in the coming days, and PM you as many as you'd like if you are really interested. I'll also post more after I give it a bath.
I'd like 975$
Title clean and in hand.
firechiken47
10-10-2015 06:16 PM
Dante93GTZ
10-18-2010 05:16 PM
tpi-hearse
06-21-2008 09:09 AM
