Firebirds Wanted Looking to buy a specific Firebird? Post your Want Ad here.
3rdgen wanted in/near ohio $3k-$4k
Old Nov 3, 2006 | 11:16 AM
88CAM305's Avatar
Car: 1988 Chevorlet Camaro
Transmission: 700-r4
Like the title says, I am looking for a good firebird, preferably a trans am. I would like one as close to stock as possible, TPI would be nice, and some t-tops, i do not care whether or not it is manual or automatic. Let me know whatcha got!!
Old Nov 5, 2006 | 08:36 PM
Shake Zula's Avatar
Car: 1986 Olds Cutlass Supreme
Transmission: 200-4R
Axle/Gears: good question...
https://www.thirdgen.org/forums/fire...ml#post3117612
Old Nov 19, 2006 | 05:24 PM
upandcoming's Avatar
Car: 88gta
Engine: 357
Transmission: 700r4/3000 stall convertor
Axle/Gears: 9 bolt 3.27
I got 1 for ya.. it is an 88 gta,maroon(needs paint)its a 305 tpi/ auto.. black interior with digital dash.t tops..Its pretty stock,has msd wires,cap,rotor,coil,air foil,flowmaster exhaust,no cat...it needs a rear main seal!!! now for the list thats already been done...... New shocks,struts,tranny mount,torque arm mount,u joints,sway bar end links(fr & rr),the track bar(the top bar above the rear end)front calipers & lines,exhaust,plugs,wires,cap,rotor,coil,starter,fans,almost all sensors,most vac. lines,fuel pump,filter...........and other things I cant think of now......This car has 213,000miles on it..it is my daily driver and I have been driving it for the last two years...It will also come with another 305(86 early 87)not centerbolt...the block and heads have already been to the machine shop..all it needs to be put together is the cam bearings pressed in and your choice of cam.....also have a spare 3.27 9 bolt rear... I am looking to get $2400 out of it all...lets make a deal!!!!!
Old Jan 14, 2007 | 04:51 PM
bsnoke's Avatar
Are you still looking?
Ben
gta90
Sep 15, 2015 04:00 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
E Rod
Aug 28, 2015 05:17 AM
Logan Bryant
Aug 27, 2015 11:52 AM
86White_T/A305
Aug 17, 2015 12:16 AM
