Group Purchases Take part in, suggest, or discuss Group Purchases here. Make sure to read the rules before doing so.
FIRST Fuel Injection TPI
Old Mar 13, 2010 | 05:04 PM
  #51
Bustionironi's Avatar
Car: 1985 IROC
Engine: 350HO
Axle/Gears: 10 bolt 3.23 limited slip
Re: FIRST Fuel Injection TPI
I have been interested in getting one of these intakes for a couple of years now. I gotta make sure that I can afford it then I will call and talk to Ken to see if I can still get a discount. I know it's a little late but it never hurts to ask.
It's going into an 86 Iroc. The motor is from an 88 Blazer. It is a 355 with the fast burn heads and a mild cam. I don't know the exact specs on the cam... I was just wondering if I would need any other parts besides the EGR?
Ted
Old Mar 14, 2010 | 02:00 PM
  #52
Blackdog36's Avatar
Car: 92 Z28
Engine: LS3
Transmission: TR6060
Axle/Gears: Strange S60 3.73
Give Ken a call, he still may be open to group purchase discount. I think besides a different style egr valve, you will need an adjustable fuel pressure regulator. Ken gave me two types that he likes to use. Only remember the below one. Would be good to have adjustable regulator since you are increasing air flow.
http://www.summitracing.com/parts/AEI-13301
Old Apr 2, 2010 | 01:42 PM
  #53
oscarfromla's Avatar
Car: 88 Iroc-Z
Engine: 355 AFR-195 FIRST Fuel Inj.
Axle/Gears: ??
Have any of you completed install of your FFI units? I was going to purchase but got into a court battle. Once it's over I want to get an FFI. Any comments on before vs. after performance?
Old Apr 2, 2010 | 08:19 PM
  #54
Blackdog36's Avatar
Car: 92 Z28
Engine: LS3
Still polishing intake. Aftermarket TPI systems like TPIS or A&M seem to yield around 20-30hp increase on stock engine. FIRST would be similar but has greater potential for more power as you add upgrades. Check out these posts for some idea.
Post #30
http://forums.corvetteforum.com/c4-t...rst-tpi-2.html
Post #110
https://www.thirdgen.org/forums/alte...runners-3.html
Old May 6, 2010 | 10:41 AM
  #55
spade's Avatar
Car: 1989 Mystery Firebird
Engine: 350 FIRST TPI
out of curiosity.... anyone install yet... been having rouble with mine... major fuel leaks... my injectors keep leaking...
gonna try what ken said and get bigger o rings....
Old May 6, 2010 | 10:43 AM
  #56
spade's Avatar
heres what it looks like right now... cellphone pic
Old Mar 22, 2012 | 03:10 AM
  #57
twest2k2's Avatar
Car: 87 Camaro IROC-Z 5.7 TPI
Engine: 350 aka 5.7L Tuned Port Injection
Transmission: 700-R4
Axle/Gears: 3.27 posi
I really want one of these intakes! Any updates or advice anyone can give me?
Old Jan 28, 2013 | 01:33 AM
  #58
Lampropeltis's Avatar
Car: '89 Flame red metallic GTA!!
TTT. I am in the market for a FIRST intake for my L98 GTA. If anyone is interested please let me know; a group discount would be great.
Old Nov 3, 2013 | 07:40 AM
  #59
JJ63's Avatar
Car: 92 Trans Am
Engine: 350 tpi
Transmission: 5 Speed
The only thing that's stopping me from buying is the throttle body that comes with the FFI.
I was thinking that a plenum can be removed from being tooled before the front is drilled and tapped. This way I can drill for the standard twin throttle body design. Plus the FFI should be cheaper without their mono throttle body.
Old Nov 13, 2013 | 07:26 PM
  #60
Keoman's Avatar
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
The front of the plenum is physically larger than the twin blade stock TB and it will not mate to the plenum without casting it differently. An adapter would be necessary.
Old Nov 14, 2013 | 09:02 AM
  #61
JJ63's Avatar
Car: 92 Trans Am
Engine: 350 tpi
I meant leaving the wall in place. I'd have to drill for the bolts and the twin 52mm throttle blades. As long as the plenum is wide enough it shouldn't be a problem.
Old Nov 14, 2013 | 12:59 PM
  #62
confucius101's Avatar
I would be in if we did a GP around Feb March
& i thought i read something about them making a tb spacer???
Old Nov 14, 2013 | 01:07 PM
  #63
Keoman's Avatar
Ken does not make a TB spacer.
I'm 99% positive that the plenum is not cast with a solid face.
Honestly there is nothing wrong with the provided TB
Old Nov 14, 2013 | 01:47 PM
  #64
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Unless your going for more of a stock look.
Old Mar 15, 2014 | 01:04 AM
  #65
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
sorry to bump this old thread but im trying to get the most info on what i would need to install this intake like throttle brackets, and how you mount the tp sensor as well i already have the intake just need to figure out the minor things
Old Mar 15, 2014 | 10:20 AM
  #66
Can you post some pictures of your intake
Is it an older version from before ken closed for retooling or one of his newer models????
Old Mar 15, 2014 | 09:35 PM
  #67
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
its the older versions i bought it from a guy tht he said has being in his shop over 5years
Old Mar 17, 2014 | 08:27 PM
  #68
dabomb6608's Avatar
Car: 86 Trans Am/85 K5 Jimmy
Engine: 406 FIRST/350 TPI
Transmission: TKO 600/700R4
Axle/Gears: 9Bolt/10Bolt front & back
Contact Ken with the email on the website. He can get you the brackets needed for the TPS/EGR block off/Throttle Cable/anything else.
When I got mine I had to order basically everything associated with it. I just got a bare intake without bolts/gaskets/ext. Even had one of the bare throttle bodys that I had to send him so it could get built.
Old Jun 9, 2015 | 04:44 PM
  #69
IROC406's Avatar
Car: 1989 Chevy Camaro IROCZ
Engine: 355 TPI w/ EBL Flash
Axle/Gears: 2.77
Is this group discount currently happening? I know this topic is an old one.
jhawkeye
May 25, 2022 06:33 PM
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Fast355
Dec 2, 2016 06:33 PM
86Base
Aug 13, 2015 05:06 PM
