Need help; I'm making a repro window sticker
Old Jul 31, 2002 | 12:03 AM
IROCZ28KevinZ's Avatar
Car: 1991 Z28 convertible
Transmission: TH-700R4
Axle/Gears: 3.73 posi 4th gen 10-bolt
Hey all; I recently got a template of a window sticker from a 1988 Buick Grand National that I'm editing so it is an exact reproduction of a 1988 Camaro window sticker. By using the template and some info found on a couple other sites, I have been able to compile a very accurate window sticker.
Then I hit the long option section.
As I went through my car's RPO codes, I found options that were standard and no cost. I found options that weren't standard but I don't know what they cost back in 1988. By usin the RPO decoder on this site, I came across options that just make no sense to me.
Here's what I'm getting from this site's RPO decoder as my RPO code meanings.
AR9 : SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
A01 : WINDOW, TINTED, ALL SHADED, W/S
B3W : Advanced Price Sheet Processing Option
B84 : ORNAMENTATION, EXTR MLDG, B0DY SIDE
CC1 : ROOF HATCH, REMOVABLE PANELS, GLASS
C49 : DEFOGGER, RR WINDOW, ELECTRIC
C60 : HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
D35 : MIRROR, OUTSIDE REAR VIEW
D6D : GEAR, SPEEDO DRIVEN
D81 : SPOILER, RR, AERO WING
D88 : DECAL, STRIPE, SPORT
E5Z : SPEEDOMETER ADAPTER (DELETE)
Unable to locate code E77 in our database!
E9Z : SPEEDOMETER KEY (DELETE)
GU2 : AXLE REAR, 2.73 RATIO
J50 : BRAKE SYSTEM, POWER
K60 : GENERATOR, 100 AMP
L03 : ENGINE, GAS, 8 CYL 5.OL TBI
MD8 : TRANSMISSION, AUTO 4 SPD, THM 700 R4
MXO : MERCHANDISED, TRANS, AUTO PROVISIONS, O/D
NA5 : EMISSION SYSTEM, FEDERAL, TIER O
NK3 : STEERING WHEEL, SPORT, SOFT RIM, SIMULATED LEATHER
N90 : WHEEL, 15 X 7,ALUMINUM CAST,4.75 INCH BOLT CIRCLE
PB4 : LOCK CONTROL, WHEEL
QYZ : TIRE ALL, P215/65R15/N BL R/PE ST TL HWY
UM7 : RADIO, AM/FM STEREO, SEEK/SCAN, CLOCK, ETR
UQ1 : RADIO PROVISIONS, FOR STEREO
U79 : SPEAKER SYSTEM, 4, DUAL FRT COAX, DUAL EXT RGE PKG
VAN : ASSEMBLY PLANT, VAN NUYS, CA
VK3 : LICENSE PLATE, FRT MOUNTING PKG
V73 : ANTENNA, FIXED
Unable to locate code WW5 in our database!
W62 : ORNAMENTATION, AERO PACKAGE
1AY : 1AY: Stock Orders Processing Option (DEALER ORDERED CAR)
1SB : OPTION PACKAGE 02
19B : TRIM COMBINATION, CLOTH, BLACK (B) (91)
19I : INTERIOR TRIM, BLACK (I) (91)
19Q : MOLDING COLOR (BLACK)
199 : SEAT BELT COLOR, BLACK (91)
41U : PRIMARY COLOR, EXTERIOR, BLACK
6XU : SPRING, COMPUTER SELECTED, FRONT, LEFT HAND
7XU : SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND
8UX : SPRING, COMPUTER SELECTED, REAR, LEFT HAND
88A : STRIPE COLOR, ACCENT, TWO TONE, GOLD/BLACK (91)
9UX : SPRING, COMPUTER SELECTED, REAR, RIGHT HAND
Unable to locate code 92F in our database!
What I need to know is how much these options cost back in 1988, and which ones came standard at no extra cost. Also, if anyone has any info regarding the "unknown" RPOs, please throw that in too!!
Thanks a lot for everyone's time!
Kev
Old Jul 31, 2002 | 05:30 AM
Matt427's Avatar
Get yourself a copy of the Camaro White Book, it has the pricing information you're looking for.
Here's an even easier solution;
www.window-sticker.com
They do good work, and I'm guessing for less money than you could do it yourself.
Old Jul 31, 2002 | 06:45 AM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
window-sticker.com does excellent work. They will reproduce the window sticker the way it would have come from the factory on the original GM paper. The last time I used them, they were $30 I think. You won't be able to duplicate it as perfectly as they can. Give 'em a try.
Old Aug 1, 2002 | 01:38 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
No RPO's - Can I simulate or can you?
I am thinking of getting a window sticker from windowsticker.com. My problem is my RPO sheet is long gone. If I listed my options could someone help me come up with the codes or is there a site that list all possible codes for 1986?:hail:
Old Aug 1, 2002 | 05:02 AM
Matt427's Avatar
The window sticker did not list every RPO number that is on the SPID label, so you only need to be concerned with the major options and packages. The information you 're seeking can be found in the Camaro White Book.
Boy, if I recommend the White Book one more time, you guys are gonna think I'm Mike Antonick himself!
BTW, window-sticker.com has a database for RPO codes for most years, so all you need to do is tell them what options you'd like to have listed on your window sticker. If you cared to, you could have them list options that were never on your car in the first place. These stickers are more of a novelty item than they are a legitimate historical document for your car. They look great, but due to the paper and the printing process, they would never pass for the original window sticker. I'm speaking from my own experience with the stickers I ordered for an '85 IROC. Perhaps in later years the reproductions would match the original sticker's printing and paper better.
Old Aug 2, 2002 | 08:02 AM
scottmoyer's Avatar
They don't create a window sticker of options you have on the car. They try to reproduce the option list that "came" on the car. If you put in a 350 that should have been a 305, they will build the windowsticker with the 305 option. Added options are not put on the sticker if it wasn't there originally. They require some information from you before they build the sticker, like a build sheet, original window sticker or RPO codes from the car. The paper is the original paper used by GM for that year.
Old Aug 2, 2002 | 09:20 AM
Matt427's Avatar
Scott, if you follow their link for how to order a sticker when you don't have any original documentation, you will see that they ask you to list your options, so I assume they take your word. They seem to prefer that you provide some type of original paperwork, but to me it looks like they will create a sticker with just the information you provide them. I agree on the engine issue, as that can be verified by the VIN, but for options such as interiors, convenience items, and paint color, the VIN does not reflect such information. Now I'm just assuming they'll do a sticker from what the customer states is on his car, but perhaps they have a database that can take a VIN and spit out a list of codes. I don't know.
PS I provided them a copy of the original "dealer copy" of my window sticker. The customer copy looked like it had been through a paper shredder.
PPS The paper I received for my '85 was not the original material used by GM. The original was a multi-page form-fed document. The reproduction was a single sheet of paper. The printing was also different. The original used a ribbon printer, and the reproduction looked like it was done on a laser printer.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
evan555222
Sep 20, 2016 02:51 AM
69 Six Pack
Oct 5, 2015 07:51 PM
budofbama31313
Aftermarket Product Review
Sep 16, 2015 12:29 PM
