Why the 5 hp gain?
Car: 99 Formula
Axle/Gears: 342
Re: Why the 5 hp gain?
Originally posted by TPIterror
Does anybody know why the 91-92 TPI motors mysteriously have 5hp more than the 90 TPI motors?
Car: Formula
Transmission: M5
Every aricle I've seen says 230 for the 91-92(5.0 TPI G92)
breaks down like this:
auto 5spd 350
1990 200 hp 225 hp 235 hp
1991-2 205 hp 230 hp 240 hp
Pistons sound about right.
auto 5spd 350
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Originally posted by 350 TPI
Also they no longer used mass air flow sensors,they changed to speed density which eliminated the MAF bottleneck.
Car: 1991 Trans Am
auto 5spd 350
auto 5spd 350
But you really can't always trust what you read in brochures is true.
Car: Formula
Transmission: M5
Some of the dealer brochures are printed before the specs are written in stone. I've seen this many times. I sold Pontiacs for 5 years.
Car: 1989 Trans Am GTA
Engine: LB9 TPI with L98 cam (Manual car)
Transmission: T5 5Speed/ 9bolt Borg-Warner 3.45 gears with posi
Originally posted by SHO350
That's funny because the brochure says for the 5.0L TPI with the 4-speed auto it has 200hp and 295lbs-ft torque. For the 5.0L TPI with the 5-speed it has 225hp and 300lbs-ft torque. And for the 5.7L TPI is has 235hp and 340lbs-ft torque.
Originally posted by LetsRock
Auto 5.0 TPI equipped cars produced less power than the 5.0 5spd versions, not sure exactly why but Ive heard it was because the auto version received a milder cam, and the 5spd received the 350 cam, am I right?
i thought this was covered a million times before. Doesnt the 90 -92 5.0 TPI Auto have the SAME cam as the 5.0 TPI 5 speed and the 5.7 TPI??? its the 85-89 TPI Autos that have the mild cam. I know the 90 TPI Auto has the smaller exhaust manifold, but i thought it had the 'good' cam.
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
