91 Z28 350 W/G92 Question
Old Oct 14, 2002 | 08:29 AM
indy82z's Avatar
Just picked up a 91 Z that was an original 350 car. It has dual cats, ect. It also lists G92 on the option Sheet, along with the 350 motor, but interestingly enough, has a drum brake rear. All the other G92 cars that I have owned were 4 wheel disc cars. It does not list the J65 code, but I thought G92 required J65??? The only thing I can think of is that all 350 cars got G92?????
Can anyone please clear this up for me???
Exactly how many 91 Z's got G92??
Tom
Old Oct 14, 2002 | 09:44 AM
extreme3rdgens's Avatar
Tom, i thought the same thing but we also just picked up a 1991 Z/28 with 350 and G92 with rear drum brakes. I have never seen a 350 car with out G92. Some one will know.
Attached Thumbnails 91 Z28 350 W/G92 Question-91-z.jpg
Old Oct 14, 2002 | 11:45 AM
HawaiiB4C's Avatar
I have seen some of these to. Kinda weird.
G80: limited slip rearend
G92: performance axle: 3.23 auto, 3.42 stick
I also thought that G92 only came on J65 cars but apprently not.
I do not have the white book but it would break down numbers between G92 and J65, if both numbers same then something wrong. If both numbers different then in fact you could get G92 without J65. Sorry i couldn't be more help.
Old Oct 14, 2002 | 12:07 PM
Sauron91's Avatar
My 91 GTA has L98 without G92..
But it has J65 and rear drums :lala: :lala:
Old Oct 14, 2002 | 02:35 PM
indy82z's Avatar
I am sure there are more cars with the G92 option than just the 350 cars. I know there are a good number of 305 5-speed G92 cars out there. I thought it was really weird, but I guess it seems to be more of the norm for at least 91's anyway.
Tom
Old Oct 14, 2002 | 05:00 PM
HawaiiB4C's Avatar
Sauron91, how can you have J65 and rear drums? J65 is the four wheel disc option.
Old Oct 14, 2002 | 05:14 PM
BLACK91TA's Avatar
what exactly does the G92 option include??? I have a 305tpi 5 speed in my 91 TA, with dual cats, and the 3.42 posi rear with drum brakes.........do I have a G92????
Old Oct 14, 2002 | 05:33 PM
HawaiiB4C's Avatar
G92 is your 3.42 rear rear ratio
Old Oct 14, 2002 | 05:35 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I have a Black 91 Z28 too with the 5.7 Tuned Port Injection L98 and G92 package....and I have drum brakes on the back.....I thought it was kind of weird too.....
Old Oct 14, 2002 | 06:48 PM
Brett Gutshall's Avatar
Yeah it says in the white book that G92 included 4 wheel disks so that is really weird.
Old Oct 14, 2002 | 07:34 PM
labrat's Avatar
Car: 87 IROC-Z
Transmission: automatic
My understanding from previous posts on this topic is that GM actually ran out of rear disc brakes in 91. And installed drum brakes in their place. Try searching the boards, this topic has come up before.
Mine is an 87 with a tpi 305, automatic, w/g92, it has rear disc brakes on it.
Old Oct 14, 2002 | 08:46 PM
1982chevycamaroz28's Avatar
my brother has a 91 z29 350 with the g92 and it has rear drums and posi.
Old Oct 14, 2002 | 08:58 PM
Black 91 Z28's Avatar
Car: 1991 Camaro Z28
I got a 91 Z28 with rear drums as well. Labrat is right from what I've heard.
David
Old Oct 14, 2002 | 11:27 PM
92GTA's Avatar
Yup, there was a point when they were having problems with the rear disk systems so they used the drums for a short time.....
Old Oct 15, 2002 | 01:17 AM
Kandied91z's Avatar
my production number is towards the tail end and i have discs........i've seen so many different things come about. as far as i know the only thing to be fact with the l98 option was it came standard with the auto and hardtop........other than that i've seen many options added or deleted over the years.
Old Oct 15, 2002 | 04:44 AM
Mikos_89's Avatar
Car: '89 GTA, '15 Camaro LS 6sp.
Engine: L98, LFX.
Transmission: 4L60, AY6.
Axle/Gears: 3.27's.
I think 92GTA is correct.
GM was having lots of problems supplying J65 rear disc brakes on G92 optioned F-bodies for the '91MY.
Maybe GM was having "supply" problems with the manufacturer (PBR?) for the rear brake calipers and decided to go back to rear-drums until the problem was solved.
I believe the rear-drums specifically used on these G92/J65 optioned cars were made of aluminum instead of the cast iron used on regular non G92 optioned F-bodies. Right? Or did the use of aluminum drums only apply to the G92/J65 rear-drum brake equipped '91 GTA's only?
Didn't GM do a similar but slightly different thing back in '82-'83 on the Pontiac Firebirds. Since they was running low on rear disc brakes for WS6 optioned T/A's, they decided to create a new (WS7) option that included all of the WS6 stuff except for rear discs.
I remember looking at a G92 optioned B2L/L98 '91 Z28 with rear drums on it a few years ago. I thought it was really a 305/LB9 being "disguised" as a 350/L98 because it had the rear drum brakes in the back.
GM does some strange things sometimes don't they?
Old Oct 15, 2002 | 06:36 AM
indy82z's Avatar
My car was a special order and it does not have J65 on the option sheet.
I will check tonight to see if it has aluminum drums or not.
I thought it was odd, as this car litterally has every option except rear disc.
Tom
Old Oct 15, 2002 | 07:25 AM
Perhaps the GTAs were the only ones with Aluminum drums because mine are cast iron. Unless I got some funky rusting aluminum :-D
David
Old Oct 16, 2002 | 12:56 PM
My option code comes up for rear drum brakes with cast iron drums on the 91 350 Z/28.
extreme
Old Oct 16, 2002 | 02:03 PM
Nice car extreme!! Could be my twin!
David
Attached Thumbnails 91 Z28 350 W/G92 Question-camaro2.jpg
Old Oct 16, 2002 | 03:15 PM
indy82z's Avatar
Yep, mine has Cast Iron drums too....
There is just nothing as sweet as a Black 91 Z!!!!
Tom
Old Oct 16, 2002 | 03:18 PM
Engine: 5.7
Nice Black 91 Z28's guys! Mine is exactly the same...but I have the SS ASCD hood
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
NinjaNife
Aug 23, 2015 11:49 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
