Restoring my 1986..I'm in college
Old Oct 28, 2002 | 07:21 PM
Zimmerman's Avatar
Here's what's wrong with my car:
1) No heater
2) Driver's side window motor misfunctioning
3) Back latch not properly attached
4) Cruise button doesn't work
5) Muffler is gone
6) Door key lock on outside is junked
I am in college, so things are going to be done cheap to fix my car.
As for the muffler, $20 I can buy one and put it on myself. The back latch can be fixed with some hardwar nuts, and some ingenuity. (may have to break down and buy the guide things)
My questions are about the window motor, and the cruise button and my door lock. I know I need to take off my stick (with cruise/blinker). I assume once I remove the steering wheel, I will be able to tell what to do next. As for the window motor, once I take off the door panel, (I know it'll be tight) could I just WD-40 the **** outta everything and hope for the best?
My door lock needs changed. I have a spare one in another Camaro. How can I exchange them? PLEASE HELP
If anyone can offer some help, please e-mail me at jozimmer@bigred.unl.edu
Thanks a ton.
Joshua
Old Oct 29, 2002 | 09:14 AM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
To really get to the guts of the steering column, you will need to rent or buy a "lock plate remover". There is a metal plate behind the steering column that needs to be pressed in and the retainer clip removed. After that, you're golden.
For the window motor, I would save up and get a rebuilt one from the auto parts store. Many of the chains give a warranty with them and WD40 won't help if the gears are stripped.
Door locks are a simple remove and replace deal. However, locksmiths can generally repair and/or rekey the locks for about $15/cylinder.
Good Luck!
skirocz28
Members Camaros
Nov 12, 2015 07:52 PM
David Frans
Oct 31, 2015 08:12 PM
mrbird
Oct 20, 2015 03:43 AM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
Zell1luk
Sep 29, 2015 10:36 AM
