If you have a Players Challenge Car, please post here. (RPO- A4U, 1LE or R7U)
#151
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: If you have a Players Challenge Car, please post here. (RPO- A4U, 1LE or R7U)
I remember reading that or hearing that the front brakes were "Caprice" rotors... I think the stock Caprice bolt spaceing was 5x5 instead of the 4.75x5 pattern we have on our cars. So redrilling them for the 3rd gen would make sence.
Thanks...
John
Thanks...
John
67restoproj (11-27-2023)
#152
T towner,
You said you had the four vin #'s for the 881le's, could you send those to me or everyone so I'm finally convinced. I know Mark said the 88 1le's were produced late in the year, but I'm still very curious.
Rob
Rob
#153
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
Somewhere I have the RPO from one of the 881LE cars. It was on eBay. Lots of us saved that JPG when it went through.
Chevy Rumble had an article a while back with one of the 88 1LE cars. Raced hard. Looked like an old race car. That accounts for 2 of the cars.
Mark.
#154
Sorry but I swore I would not give out the VIN's....that's the only way I got them.
Tomorrow I will compare the 1LE vin's to the 88 Players cars I have to see where they fall in the mix (can't believe I haven't already.).
Last edited by t_towner; 02-01-2009 at 06:56 AM. Reason: Content didn't match facts
#155
Facts about 1988 1LE Cars:
Below is a summary of information I have obtained from various sources including a current 1988 1LE owner and my two players challenge cars (a Camaro and a T/A.) Can't believe I haven't done this before.....was very surprised at the findings.
1988 Players Challenge Cars (were delivered w all 1LE components and more)
- Both A4U cars I have were built in Febuary 1988.
- The Camaro has Vin sequence of: 14XXXX
- The T/A has VIN sequence of: 22XXXX
The 1988 1LE's:
- The Camaro's have a Vin sequence of: 19XXXX
- The T/A's have a Vin sequence of: 26XXXX
- They were built relatively close together (as I assume the Players Cars were)
- Were built at the END of 1988 production.
I looked back through my notes and the owner of the 1LE stated his car had a Certificate of Origin from early September 1988.
This would mean the 88 1LE's were some of the last production cars built for the 1988 model year.
Therefore it seems the 1988 Players cars are technically the first 1LE's!?
I've heard from 2 sources the 1LE cars were needed in the US to legitimize the export of the Players Cars? This would seem to make some sense based off the build sequence but I'm not sure of the reasons.
Thoughts?
The 1988 1LE's:
Thoughts?
#156
Mark I'm stilll puzzled to t t's research, is he right? Any idea of many players cars were built in 88?
#157
#159
Engine: TPI(s)
The 1988 1LE's:
Thoughts?
The 1988 1LE's:
Thoughts?
Mark.
#160
Engine: TPI(s)
#162
Re: If you have a Players Challenge Car, please post here. (RPO- A4Q, A4U, or R7U)
Hi, I thought that I just bought at the very least a 1le but when I got the vin decode at the dealership it doesn't show any of the good stuff no 1le, ru7 but the car has everthing aluminium calipers aluminium driveshaft, oil cooler wonderbar, chalk marks on motor you can even see where the players sticker was at one time, need help with trying to verify
#163
Greg
#165
Hi, I'm sure I have one, it has all the right stuff on it, it's a 91. I went to the dealership to get my rpo codes as the sticker is missing off the rear compartment and none of the right codes come up. It's a z28, but the rpo codes I got say it has a G80, gu2 axel, when I know it has the big brakes and aluminium pbr calipers, the car has it all, aluminium driveshaft, wonderbar, oilcooler, chalkmarks on the motor, any help would be appricated. Is it possible all the good stuff was transfered to a regular z28, due to a crash or a 1le that was not repairable? Would you have a vin list for a situation like that? Thanks
#166
#170
Car: 87 player's trans am a4u (pepsi car
Engine: 305 tpi
Axle/Gears: 3:42
Could have been a promo car maybe? If it is real, 1le r7u will come up when you run the vin. Maybe you're right and someone installed the parts after a wreck? Maybe Mark has a thought on this.
#171
Engine: TPI(s)
If you PM me your VIN, or the last 6 digits, I can check it against the ones I know and I can tell you if it is in the right range. If the GM parts counter does not show the 1LE or R7U and the car is a 91, then it was not a Player's car. So then I would guess someone swapped the parts. To verify that, you need to check the VIN number on the motor. Many player's motors were sold after the seasons as teams could re-race a 1991 car in 1992 (or in 1991 as the 1991 model was used for two years). So finding a players motor is not uncommon.
Start with the basics ... VIN first. Then go from there. Drop me a PM.
Mark.
Mark.
#172
Sorry, Mark I'm a little new at this stuff, what does PM mean, I thought I was doing good to get the pics up, thanks
#173
Engine: TPI(s)
#174
Car: 2003 BMW E46 M3 Vert
Engine: 3.2 I6 M power 333 h.p.
Transmission: SMG 6 speed
Axle/Gears: 3.62 posi
I am looking to buy this 1LE. What is rpo R7H?
#175
This may seem meaningless, but...
R7H - Control, Sales Item No .33
John
John
#176
#178
Engine: TPI(s)
R7H, like R7U is a marketing package, which is a combination of options for a specific purpose. R7U is well defined as a Canadian Player's car. If this is a Canadian car, we could look it up though Vintage Services and see what they can tell us. If USA car, then I'm not sure. Need someone in the know of 1LE cars that might recall a package or program where it might have been used.
Mark.
Mark.
#179
Mark.
Mark.
#180
cool section!....my friend Mark Schill was a driver/owner in the series...I'll see if I can get him to post...doug
#181
Engine: TPI(s)
NEWS FLASH!!!
I've been able to document ALL the 1992 1LE R7U Camaros. I now have details on the options and colors. I'll be updating my production number chart to reflect the 1992 Camaros. The rarest car was a dark red with a red interior ... only 1.
Hopefully tonight I will update the chart.
Mark.
Mark.
#182
Engine: 305 tpi
Axle/Gears: 3:42
Hey Mark, any updates on the players site yet?
#183
Engine: TPI(s)
I have to make more time and scan in a bunch of info. Have to see what would be the most useful information to post up. Decal locations are key for people restoring cars. Tech specs are always good. The lastest info on 1992 color combinations was pretty cool to find.
It's a winter project. Need a cold day for motivation.
Mark.
Mark.
#184
Quick question to add to the thread.
I've seen two ebay listings now for 1LE's, (not R7U cars mind you), where the ad states the car is # so and so of the total production. (Anyone see the 'red '92 with the tan leather gut just recently?) I didn't think there was any such recorded info at GM...Can anyone confirm?
My '91 1LE is an early production Canadian import (5sp/LB9). I have read the break down for 5spd's vrs auto 1LE's, but have never come across any documentation that states the actual build #; nothing like the '89 TTA's for example...
Anyone chime in?
Thanks,
-Andrew
Anyone chime in?
Thanks,
-Andrew
#185
Engine: TPI(s)
Anyone chime in?
Thanks,
-Andrew
Anyone chime in?
Thanks,
-Andrew
#186
There was 134 1LE camaros in the 1991 model year. Get a GM Vintage package for your car and you should have more info (was yours a 1990 production ot a 1991 production). I have the player's info, so you can subtract that info from the numbers and yours would be the few non-players 1LE cars.
I never bothered with the GM historical services paperwork as I have most of the original paperwork from day one.
This 1LE is a '90 build, shipped to Humberview motors in Etobicoke (Toronto) Ontario Leased in Dec of 1990.
-Andrew
#187
Engine: TPI(s)
About the best guesswork I can do.
What is the build date on your car? Leased in December suggests that it might be a 1991 production year. It's tough to say. The R7U cars were batched built, so I have the breakdown of how many were made for 1990 and 1991.
Mark.
#188
Mark,
Winter is here, had a chance to check my vin. I was able to contact the original owners daughter on how he new to order the camaro stripped but she seemed hesitant to help me.
#189
Engine: 305 tpi
Axle/Gears: 3:42
Re: Database of Rare Models?
Just re-read this post. Does anyone else have an 87 a4u on this site? Just curious. And if so , where are you?
#190
Engine: TPI(s)
1992 R7U Color Breakdown!!!
1992 Camaro R7U 1LE
5 - Quazar Blue
2 - Dark Teal
6 - Bright Red
2 - Dark Red
3 - Black
9 - Artic White
3 - Purple haze
23 - Grey Interior
6 - Black Interior
1 - Red Interior
1992 Trans Am R7U 1LE
1 - Green Metalic
1 - Quazar Blue
2 - Artic White
1 - Copper
2 - Black interior
3 - Grey Interior
... I'll format it and add it to the GIF production number image at the front of the posting.
Mark.
1992 Camaro R7U 1LE
5 - Quazar Blue
2 - Dark Teal
6 - Bright Red
2 - Dark Red
3 - Black
9 - Artic White
3 - Purple haze
23 - Grey Interior
6 - Black Interior
1 - Red Interior
1 - Green Metalic
1 - Quazar Blue
2 - Artic White
1 - Copper
2 - Black interior
3 - Grey Interior
Mark.
#191
THat is really sweet... how did you figure that out?
John
John
#192
Car: Used to drive a camaro
Anyone chime in?
Thanks,
-Andrew
Anyone chime in?
Thanks,
-Andrew
#193
Engine: TPI(s)
#194
Engine: 305 tpi
Axle/Gears: 3:42
Goofing around on the 'net, found the red on red leather car forsale the other day. wanted big dollars for it as it was never raced. low miles garage kept. dealer has it.
#195
I saw the same red car I think. The only thing left original on mine is the unibody, dashpad, and rear spoiler.EVERYTHING else has been replaced. Granted I installed alot like a Strange rear end, Tremec transmission, a 383 and a supercharger. I bought the car because is had 19,000 miles and was in 110% condition. Only has 46,xxx miles now.
IMO the B4C's,1LE's,R7U's are the greatest 3rd gen's to have. I hope you guys hold on to them.
#196
Engine: TPI(s)
Whew! A busy day. The Player's registry is starting to take off. I have documented ALL of the 1991 and 1992 VINs for both the Camaros and T/As. I have all the option codes and color combinations. Just working on the 1989 cars.
Here are some highlights (1992 had the oddest color combinations).
Camaro Colors:
1991 (1990 production)
Artic White - 43
Bright Red - 0
Black Saffire - 9
Black - 1
Med Green Metallic - 0
Quazar Blue - 0
Copper Beige - 0
Red Metallic - 2
Bright Red - 10
Dark Teal - 0
Purple Haze - 0
1991 (1991 production)
Artic White - 19
Bright Red - 0
Black Saffire - 2
Black - 5
Quazar Blue - 0
Copper Beige - 0
Red Metallic - 1
Bright Red - 5
Dark Teal - 0
Purple Haze - 0
1992
Artic White - 9
Bright Red - 0
Black Saffire - 3
Black - 0
Quazar Blue - 5
Copper Beige - 0
Red Metallic - 2
Bright Red - 6
Dark Teal - 2
Purple Haze - 3
Trans Ams 1991 (1990 production)
Artic White - 12
Bright Red - 1
Black Saffire - 1
Black - 0
Quazar Blue - 0
Copper Beige - 0
Red Metallic - 0
Bright Red - 0
Dark Teal - 0
Purple Haze - 0
Artic White - 4
Bright Red - 2
Black Saffire - 2
Black - 1
Quazar Blue - 0
Copper Beige - 0
Red Metallic - 0
Bright Red - 0
Dark Teal - 0
Purple Haze - 0
1992
Artic White - 2
Bright Red - 0
Black Saffire - 0
Black - 0
Med Green Metallic - 1
Quazar Blue - 1
Copper Beige - 1
Red Metallic - 0
Bright Red - 0
Dark Teal - 0
Purple Haze - 0
Interior colors are pretty basic.
Camaro 1991 (1990 production)
Grey - 33
Black - 23
Red - 9
Grey - 16
Black - 14
Red - 2
1992
Grey - 23
Black - 6
Red - 1
Trans Am 1991 (1990 production)
Grey - 14
Black - 0
Red - 0
Grey - 7
Black - 2
Red - 0
1992
Grey - 3
Black - 2
Red - 0
If anyone wants to confirm a 1991 or 1992 car, I now have all the VIN's and RPO sheets.
Mark.
Camaro Colors:
Artic White - 43
Bright Red - 0
Black Saffire - 9
Black - 1
Quazar Blue - 0
Copper Beige - 0
Red Metallic - 2
Bright Red - 10
Dark Teal - 0
Purple Haze - 0
Artic White - 19
Bright Red - 0
Black Saffire - 2
Black - 5
Quazar Blue - 0
Copper Beige - 0
Red Metallic - 1
Bright Red - 5
Dark Teal - 0
Purple Haze - 0
1992
Artic White - 9
Bright Red - 0
Black Saffire - 3
Black - 0
Quazar Blue - 5
Copper Beige - 0
Red Metallic - 2
Bright Red - 6
Dark Teal - 2
Purple Haze - 3
Artic White - 12
Bright Red - 1
Black Saffire - 1
Black - 0
Quazar Blue - 0
Copper Beige - 0
Red Metallic - 0
Bright Red - 0
Dark Teal - 0
Purple Haze - 0
Artic White - 4
Bright Red - 2
Black Saffire - 2
Black - 1
Quazar Blue - 0
Copper Beige - 0
Red Metallic - 0
Bright Red - 0
Dark Teal - 0
Purple Haze - 0
1992
Artic White - 2
Bright Red - 0
Black Saffire - 0
Black - 0
Quazar Blue - 1
Copper Beige - 1
Red Metallic - 0
Bright Red - 0
Dark Teal - 0
Purple Haze - 0
Grey - 33
Black - 23
Red - 9
Grey - 16
Black - 14
Red - 2
1992
Grey - 23
Black - 6
Red - 1
Grey - 14
Black - 0
Red - 0
Grey - 7
Black - 2
Red - 0
1992
Grey - 3
Black - 2
Red - 0
Mark.
#197
Thanks Mark--great info!!
#198
Engine: TPI(s)
Check page 1 of this posting for a complete listing of the 1986-1992 Camaro color production numbers!
Mark.
Mark.
#199
Engine: TPI(s)
IT IS COMPLETE!!! THE PLAYER'S CAR REGISTRY IS COMPLETE!!!
After 9 years, I finally have every VIN and RPO for every Player's car made! See the updated color breakdown by car.
I can now offer the ability to verify a car as authentic, as well a provide a breakdown to color as well as what sequence it was in the batch. Free service I might add. :-)
Turns out my 1988 TA was the last one to roll of the assembly line for the 1988 model year. Sort of cool info.
Enjoy!
Mark.
Enjoy!
Mark.
#200
Car: Camaro
Engine: 6.2L
Mark we all owe you a debt of much more than thanks for all your undying efforts to put all this info together and publish it. I know you helped me out a lot when I bought mine verifying its authenticity and colour scheme etc. Very helpful for me and everyone else whom you've heard from too Im sure.
Now we should start working on reuniting the cars for a big race somewhere, sometime in the future. That would be awesome and once the economy rebounds might even garner some corporate sponsorship
Perhaps Im over dreaming here but thanks again.
