Trans-Am Recaro Edition Build Sheet Info needed
Car: '84 Trans Am Recaro Edition
Engine: L69 305 H.O.
Transmission: 700-R4
I'm trying to find the build sheet of my Recaro.I looked at it once but i didn't remember at that time where the build sheet was located.Now i know it and i'm gonna check if i have one.But before checking i wanted to ask since there are some ppl who has some experience with recaros if they found one before?If the answer is yes, where?Or maybe it doesn't even exist.
Car: 1982 Recaro T/A
Engine: LU5 CFI 305 V8
Transmission: TH-200C
Axle/Gears: 3.23 F-body Fanatic: Yes
I have an 82 Recaro. I took out the back seat bottoms and looked all under there under the acoustical insulation, found nothing. Also removed trunk rear-most panel and looked under trunk carpet, found nothing. I didn't take the carpet out, just pulled it up some and felt all around under there. Used mirror to look up under driver's seats, nothing. Felt under there by hand, Nothing. Looked briefly in spare trunk area, nothing. As far as I remember, I've never seen one from a Recaro
