1982 history question...
Axle/Gears: 3.45, 3.27, 3.27
Can someone look up for me what vin number GM Switched front sway bar mounting brackets from the 14019271 (straight bolt pattern) to the 14041898 (offset bolt pattern)? I know it was a mid-year switch in 1982. In fact I've seen some cars where the 14019271 brackets were re-drilled by GM to accomodate the new pattern of offset mounting bolt holes. If the vin is different for Camaros & Firebirds I'd need both if possible. Thanks.
Lon
Lon
Linson
Oct 1, 2015 09:50 PM
