Reproduction RPO sheets?
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
Does anyone know where I can get a reproduction RPO sheet for my car? Mine is currently in my console on the side of the bin but its all cracked and is getting replaced. Plus one corner of the current sticker is kinda scratched up and hard to read. So where can I get a new RPO sticker at? Also, is it possible to get a buildsheet made from the RPO codes and a VIN? Im sure my car still has its original buildsheets but I havent looked for them yet. They are probably in craptastic shape anyway. Thanks for the help guys.
Car: 1982 Recaro T/A
Engine: LU5 CFI 305 V8
Transmission: TH-200C
Axle/Gears: 3.23 F-body Fanatic: Yes
I don't know of anyone that makes reproduction RPO stickers.
as far as piecing together an RPO sticker from a build sheet, that should be possible, since the build sheet also has all the codes. But you can't do the vice versa, you can't possibly make an accurate build sheet from an RPO sticker because the build sheet has a lot more info on it, such as the dealer name, the actual weight of the car, the date build, job number, plus all those zillions of little broadcast codes at the top which correspond to the parts placed in the car but are hard to decode into something meaningful.
