rear discs
Old Feb 25, 2003 | 08:40 AM
no_car_yet's Avatar
rear discs
my car has the WS6 rpo code. it does not have rear disc's which are supposed to be a part of ws6. do i hnot have this because of the 305. what else was offered that i don't have?
Old Feb 25, 2003 | 09:07 AM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
Disk brakes were only included in the WS6 package in earlier years 82-85(?).
Old Feb 25, 2003 | 12:36 PM
92GTA's Avatar
You must have the 305/auto. You could not get rear disks with the 305/auto combo, only the 305/5-spd or the 350/auto...
Old Feb 27, 2003 | 12:56 AM
MdFormula350's Avatar
i would just find a rear end (10 bolt) with posi and disk brakes and swap that in..
ws6 was more suspension oriented like springs and sway bars..
Old Mar 3, 2003 | 10:06 AM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
wow, when did they start to not allow you to get 305 auto with rear discs?
Old Mar 3, 2003 | 11:51 AM
92GTA's Avatar
Around the time the L98 became available I believe, not sure on the exact year though. It could have been 87 when the L98 came out but I'm not sure.
Old Mar 3, 2003 | 02:23 PM
Duke901's Avatar
Car: 89 Formula
My 85 iroc has a tpi 305, auto with rear disk.
Old Mar 3, 2003 | 02:38 PM
indy82z's Avatar
I had a 87 Iroc with a 305 TPI, G92 and 4 wheel disc brakes. It was an automatic.
Tom
Old Mar 3, 2003 | 03:52 PM
Krazzycowgirl's Avatar
Car: 87 Irocz, 95 Z28, 71 Z28 /RS
Engine: 355 Tpi, LT1, 355
Transmission: Auto, Auto, 4sp
The L98 came out in 87 yes you are right.
My 82 camaro & My 87 iroc both have disc brakes
Old Mar 3, 2003 | 04:26 PM
patrickm00's Avatar
i had an 88 GTA 305/auto rear discs
Old Mar 3, 2003 | 05:36 PM
92GTA's Avatar
Pherhaps it was just a 91/92 thing on Firebirds then because I can look at my 92 brochure right now and it says that you cannot have rear disks with the 305/auto combo and I know 91 would be the same...
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
zayne0
Aug 24, 2015 07:22 PM
