Fuel tank Capasity
Based on how often I fill my tank, I think it's more like 9.5!
I usually only get about 150 miles to a tank. I need to keep the foot off the "GO" pedal.
The answer is approximately 16 gallons. In some years it was posted as 16.2, 15.8 and 15.5, so the above reply at 15.5 might be what was listed for your year/body car. Get gas at 1/4 tank and you won't need to worry about it.
Car: 1986 Trans Am
Engine: 5.7L TPI
thank you guys very much for the help, its greatly appreciated :lala: Trending Topics
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I have read where the 1LE cars and the TTA cars got a larger tank, (18 gal) BUT I have yet to actually confirm that in the parts catalogs
John.
John.
my 87 Owners Manual "58.7 Liters (15.5 Gal.)" Just to confirm what has been confirmed...
John
John
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
hey guys lemme ask yall a question...
usually when i fill up its on the 1/8 tank mark and itll hold 14 gallons or so..
when i filled it up one time it was sputtering as i was pullin into the gas station and it took 18.3 gallons...
im confused
im confused
EITHER: your name sais it all, OR I would never go back to that station, considering that they might not be measuring a gallon to be a gallon. I guess there would be a possibility that someone had put a 1LE tank in your car...
Something to consider that your fuel system by the time you figure your fuel lines is about an extra half to full gallon. Then there is the filler neck. If I park with my car on a slight hill where the filler neck is on the high side of the hill, I can usually get a little extra fuel in my cars.
John
John
im confused
im confused
Glowsock
Aug 26, 2015 12:28 AM
AkDrifted
Aug 17, 2015 07:45 PM
