RPO Questions
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
RPO Questions
I finally got around to running my rpo codes on this site. I found 3 that were not found in data base. Can anyone tell me what they are.
Anyway, I didn't find anything surprising. O well.
AJ3 : RESTRAINT SYSTEM, FRT SEAT, INFLATABLE, DRIVER
AR9 : SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
B34 : COVERING, FRT FLOOR MATS CARPETED INSERT
B84 : ORNAMENTATION, EXTR MLDG, B0DY SIDE
C60 : HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
D3V : GEAR, SPEEDO DRIVEN
D35 : MIRROR, OUTSIDE REAR VIEW
D8N : SENSOR, VEH SPD
D80 : SPOILER, RR END PNL
E5Z : SPEEDOMETER ADAPTER (DELETE)
E9Z : SPEEDOMETER KEY (DELETE)
FE1 : SUSPENSION SYSTEM, S0FT RIDE
GU5 : AXLE REAR, 3.23 RATIO
Unable to locate code IPB in our database!
J41 : BRAKE SYSTEM, PWR, FRT DISC, RR DRUM, CAST IRON
K60 : GENERATOR, 100 AMP
LH0 : ENGINE, GAS, 6 CYL, 3.1L, MFI, V6
MD8 : TRANSMISSION, AUTO 4 SPD, THM 700 R4
Unable to locate code MX0 in our database!
NA5 : EMISSION SYSTEM, FEDERAL, TIER O
NK3 : STEERING WHEEL, SPORT, SOFT RIM, SIMULATED LEATHER
N90 : WHEEL, 15 X 7,ALUMINUM CAST,4.75 INCH BOLT CIRCLE
QPH : TIRE ALL, P215/65R15/N BL R/PE ST TL AL2
Unable to locate code R8T in our database!
UB3 : CLUSTER, INST, OIL, COOL TEMP, VOLTS, TRIP ODOM, TACH
UN6 : RADIO, AM/FM STEREO, SEEK/SCAN, AUTO REV MUSIC
UQ1 : RADIO PROVISIONS, FOR STEREO
U79 : SPEAKER SYSTEM, 4, DUAL FRT COAX, DUAL EXT RGE PKG
VAN : ASSEMBLY PLANT, VAN NUYS, CA
VK3 : LICENSE PLATE, FRT MOUNTING PKG
V73 : ANTENNA, FIXED
Y86 : MERCHANDISED PKG, CAMARO RS
1AY : 1AY: Stock Orders Processing Option (DEALER ORDERED CAR)
1SB : OPTION PACKAGE 02
37P : WHEEL COLOR, DK BRIGHT TEAL MET (91)
37Q : MOLDING COLOR, DK BRIGHT TEAL MET
37U : EXTERIOR COLOR, PRIMARY (DARK BRIGHT TEAL METALLIC) (92)
6XS : SPRING, COMPUTER SELECTED, FRONT, LEFT HAND
7XS : SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND
8UY : SPRING, COMPUTER SELECTED, REAR, LEFT HAND
82B : TRIM COMBINATION, CLOTH, MED DK GRAY (91)
82I : INTERIOR TRIM, MED DK GRAY (91)
829 : SEAT BELT COLOR, MED DK GRAY (91)
9UY : SPRING, COMPUTER SELECTED, REAR, RIGHT HAND
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
mx0 strictly means that your car came with an automatic from the factory. md8 lists the specific transmission, in this case, a 700-r4.
Engine: 350 S-TPI
Darn, I was hoping for some cool feature I didn't know about. O well, looks like its bare bones as it comes.
hectre13
Dec 11, 2023 08:14 AM
Thornburg
Aug 25, 2015 01:46 AM
