Engine Block Numbers
Old Jun 3, 2003 | 05:12 PM
berklified's Avatar
I was told that my 82 camaro had an engine swap before i bought it and was upgraded to the 88 5.7L 350, with a carb
now my question is where would i find the block id number to confirm this
reason i ask is because i just recently replaced my water pump, the pump works fine, but it didn;t seem to have all of the bolt up holes for my alternator brace and my steering pump brace. they are attached, just not as securely as before. did i get the wrong water pump? did they stop making it with bolt ups? did the previous owner use a wierd setup and change how things were bolted up?
so where can i find my block id tag?
-mark-
Old Jun 3, 2003 | 07:53 PM
Skatepunk60's Avatar
Car: Hardtop 84' z/95' Cheyenne
Engine: 305 H.O./4.3L
Transmission: 5-speed manual/Auto
Right on the back behind the driver side head where the bellhousing bolts to
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
Reddeath210
Oct 6, 2015 08:20 AM
lakeffect2
Aug 23, 2015 08:44 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
