Prototype Turbo V6 Iroc
Old Feb 14, 2011 | 05:36 AM
  #51
angelbirdv8's Avatar
Car: 1992 camaro rs t-tops
Engine: 305 tbi
Transmission: 5 speed
Axle/Gears: 373
Re: Prototype Turbo V6 Iroc
Originally Posted by Timinsk
those 3.4L v6 back in the 80's i heard were the most indestructible blocks chevy has ever made. supposively you can run the same motoroil in it over 200k miles and still run like a chime. Also there was a test too i heard.. never seen the video but they ran about 3.5k miles a day and 5k rpm and did that every day.. but this is what i heard..
but this would have been a great production model for gm to make, i bet it would of sold sooo many!
Yes i can vouch for the 4.3l gm motors and the fact that i havent changed the oil in my s10 in three years jus add oil wen it needs it lol
245,000mi and still ticking
Only problems have been starter and waterpump
Also definately glad u found the article and wouldve made a great production car i think
Old Feb 14, 2011 | 08:15 PM
  #52
91 zeee's Avatar
Car: 1991 Z-28
Engine: 383 TPI
Re: Prototype Turbo V6 Iroc (and Article)
Originally Posted by Black 91 Z28
I was curious if anyone had ever heard anything about a Prototype Turbo V6 Iroc? I was digging through some old magazines and found an article on it. The article is from the March 1990 issue of "Turbo". It used a Turbo and intercooled 4.3L an made 295 HP and 385 TQ. They ran a best 0-60 of 5.98s (using something called a Vericom) and a best quarter at 14.77 at 94.6 with a less than purfect launch.
Anyways, I wasn't sure if everyone knows about this and I missed it or what. If yall want I'll try to get the article scanned in the next few days.
David
Would it be possible to post this permanently under the 'media' section of TGO?
Old Feb 21, 2011 | 08:14 AM
  #53
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
not changing your motor oil will certainly lead to ticking... followed by knocking and seizing shortly after.
Old Feb 21, 2011 | 12:10 PM
  #54
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Jeremy,
If I understand him correctly, he is always changing oil... its not a pour this out and add that... Its Burn this off (or it leaks out) and add that.
I will concede that yes it is a good way to get gunk buildup...
John
Old Feb 21, 2011 | 01:06 PM
  #55
JeremyNYR's Avatar
Car: 1984 Trans Am
Originally Posted by okfoz
Jeremy,
John
My wife had a saturn with the dohc 1.9L I4 that was notorious for burning oil. I added a quart between oil changes and still did full oil changes every 3,000 miles. Just adding a quart every 1,500 miles and never draining it sounds like a really really bad idea to me.
Old Feb 21, 2011 | 01:29 PM
  #56
okfoz's Avatar
I agree 100%, not a wise thing to do IMHO.
I had a 1990 Riviera, with the 3800, at 3000 miles without fail it would give me a low oil light... it was always 1/2 qt low... I always knew when to change oil in it.
John
Old Feb 21, 2011 | 01:51 PM
  #57
JeremyNYR's Avatar
Car: 1984 Trans Am
haha, that sounds very convenient. I keep track of all maintenance I do, including oil changes, on a piece of paper in the glove box with the date and milage for each item. I don't do it for my Trans Am though because I never seem to drive it more than 3,000 miles in a year! 1 oil change every spring is all it needs.
Old Feb 21, 2011 | 03:50 PM
  #58
okfoz's Avatar
On my daily driver, I actually go one step further, I have a list of all gas fill-ups. I keep track of Miles, MPG (as per ECM), Fuel used (as per ECM), Actual Fuel (as per pump) Date, Exterior temp, and Pump number... The Data is fascinating, I have actually learned that at some gas pumps at the same station I get more gas per fill-up, so I use that pump when its open...
I have a separate paper for the repairs, and oil changes... I made a nifty chart for both if anyone wants me to upload it... How we got here I have no idea.
ZZ3Astro
Aug 13, 2019 12:57 AM
Vojtush31
Oct 11, 2015 01:07 PM
sleprock
Oct 1, 2015 09:39 AM
PestilenceIV
Aug 20, 2015 03:32 PM
PestilenceIV
Aug 20, 2015 02:33 AM
