91 RS Convertible
Car: 86 T/A
Transmission: 700-R4 Auto
91 RS Convertible
Im thinking about buying this white 91 RS Convertible and was wondering what engine did it come with stock? Im curious if its a 6 or 8 cylinders. Does anyone know? Here is the link
http://www.autotrader.com/findacar/v...or=&cardist=11
Car: 1991 Formula
Engine: 350 firebreathing inches of Small Block Chevrolet
Transmission: A 700R4 that has trouble handling the formentioned 350.
I would image from the pic's a 305 TBI, actually I think all '91 and '92 RS Convert's were 305 TBI.
Looks nice, Later, Garrett
Car: 87 IROC-Z
Transmission: automatic
The 305 was standard, but you could get a v-6 and credit delete if you really wanted a v-6 badly enough.
Most likely it a 305.
Car: 1991 T/A - Sold (sniff) 1980 T/A Pa
To me, the door and spoiler are the same color, but the rear quarter isn't. It could be a shadow, or that the door isn't closed all the way. The hood lines up with the front clip about the same as I've seen on most Camaros, but the hood to fender gap appears to increase as it gets closer to the nose. It could be that, like my car, the hood sticks up slightly at the bottom. Interestingly enough, the ground effects on the front 1/4 appear to be pulled away from the fender below the marker light. On the bright side, the door seam appears to be constant in relation to the fender.
The front wheel, being turned towards the camera, causes a slight optical illusion that compunds all the problems that picture has. Low res, poor composition and incorrect lighting are a used car sellers best friend.
Thirdgen89GTA
Nov 26, 2015 11:04 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
