mandatory posi rear w/ rear disc brakes?
Car: 85 Iroc-Z
Axle/Gears: 10-bolt 3.42
were there any circumstances where a posi rear was mandatory when you ordered a camaro with rear disc brakes?
Car: 87 IROC-Z
Transmission: automatic
from 1987 on if you wanted rear discs you had to get posi also, it was part of the package options that were availble those years. Prior to 87, posi and rear discs were seperately available options.
Car: 87 IROC-Z
Yes, but posi and rear disc's were seperate options from 82-86. There are some members of this board that have non posi rear ends but still have rear disc's on their 85's.
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
the rear discs are the iron Delco-Moraine style.
Never hear of that, does anyone have anymore info on it? Thanks.
Kevin
Gearhead...,
I guess the only thing you need to know about those iron calps is to avoid them. They were the subject of a recall in stick shift (but not automatic third gens). I've got the PBRs in my garage and Dyno Don has a 9 bolt sitting around. All I need is the money.
AFAIK, the posi and 4-wheel discs were standard with the F41 sport suspension.
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Those iron calipers are GARBAGE. Ask me how I know this.
Anyway, I'm yet another 85 owner that had disk brakes and no posi.
Let's just say that my stopping distance would be considered "good" for a fully loaded log truck. For a sports car, not so good.
Car: 85 iroc z
Engine: LG4 :(
Transmission: 5 speed
Curious on the recall of the iron calipers. What was it exactly, and what did they replace them with.
I guess I better find out if I have any outstanding recalls on my car.
And yes I also have a non-posi with the rear disk set up.
Engine: L98 350 TPI
So I take it Auto Rear disc brake cars got aluminum calipers??
Kevin
Kevin
Engine: L98 350 TPI
So what 85 86 rear disc cars did NOT come with iron rer calipers?
Kevin
Kevin
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Kevin
Kevin
Engine: L98 350 TPI
Kevin
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
