Original Block?
Old Mar 22, 2004 | 10:54 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Original Block?
Hey guys, I wanna know if this is the original block to my Camaro. Its a '83 Z28 with the L69 engine (my reason for using the 305) but I want to make sure its the original block. If its not, I might as well build something better.
Anyway, the casting number checks out (14010203) as 80-85 305ci 2 bolt.
The number on the machined pad on the passenger side deck of the block is VO513DDY with what looks like a VIN number below it, although since I painted the block (and the pad) I can't read the last 4 numbers of the VIN.
Can anyone decode the pad numbers for me? I would really appreciate it. Thanks
Old Mar 22, 2004 | 11:28 PM
82RECAROTA's Avatar
VO513DDY
V = Flint, Mi
0513 = May 13
The DDY Suffix Code checks out as being used on the '83 L69. It was also used on the '83 LU5; but then again they are same engine except for the cam, intake and exhaust manifolds, and carb.
Old Mar 23, 2004 | 04:17 PM
Air_Adam's Avatar
Cool... thanks alot Recaro
jhawkeye
May 25, 2022 06:33 PM
deracer
Apr 11, 2016 12:04 AM
gixxer92
Sep 1, 2015 04:32 PM
camaro71633
Sep 1, 2015 10:24 AM
theurge
Aug 21, 2015 12:46 PM
