Did GTAs come with Wonderbars?
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
Pontiac and Chev choose to engineer handling differently. Pontiac used THICK sway bars, Chev used smaller sway bars, but added the chassis stiffener. Also, a Camaro and Trans AM had different weights front/rear.
It is surprizing that they did not put the bar on the T/A as well. But perhaps the 36mm front sway bar made up the difference.
Mark.
Mark.
Engine: TPI(s)
Based on the comments people say about how much sub frame connectors change the car, I Would guess than any amount of chassis stiffening would be a good idea.
For it would come down to cost. It is was $25 ... why not. IF it was $250 ... it might not be worth it.
Mark.
Mark.
Guest
Posts: n/a
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I got mine from TDS and I am really impressed with it, I have not put it on but for $50 it made a nice Birthday gift to myself
John
John
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The wonderbar helps protect the steering box area, which apparently is prone to cracking with 16 in wheels. By the way, Global West's version is actually called a steering box brace, I believe.
JamesC
JamesC
Car: 88 TBI Formula, 98 LS1 TA, 77 400 T
I noticed a HUGE difference in my 88 Formula. Went from understeering to more neutral. Silenced a couple of creaks and groans too. All in all the front end feels more solid. If you have already installed strut tower brace you might not notice anything.
trade you the woderbar for your GTA
I heard it helps the area around the steering box so I think I will keep it. But if you want to trade its yours.
Also I think it helps to prevent the cracking.
Also I think it helps to prevent the cracking. Thread
2012sergen11
Oct 13, 2015 07:38 PM
And for 50$ Thats a helluvadeal.
