What is this?
Old May 11, 2004 | 09:14 PM
Farfire70's Avatar
What is this?
The guy I bought my car off of had this with the original owner's manual and the warranty card that came with my car. Does anyone know what this is?
Old May 11, 2004 | 09:19 PM
Farfire70's Avatar
Old May 11, 2004 | 09:53 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
looks like a spare key/card that you can put in your wallet just in case you lock your keys in your car, you can still get in.
Old May 11, 2004 | 10:47 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
That's what it is all right, hadn't even been cut either. Don't see too many of those around anymore.
Old May 12, 2004 | 06:49 AM
Farfire70's Avatar
so it's supposed to be cut to match my keys?
Old May 12, 2004 | 08:45 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Yep, it was designed to be cut for the door key and carried in your wallet or purse (depending on owner) for emergencies where you had locked your keys in the car.
Old May 12, 2004 | 09:10 PM
Farfire70's Avatar
clever. A good idea and something cool that came with the car.
Old May 14, 2004 | 02:11 PM
Drakar's Avatar
The original "Onstar"
Old May 14, 2004 | 07:21 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
LOL!
Old May 14, 2004 | 08:31 PM
ershealy's Avatar
Car: 88 TBI Formula, 98 LS1 TA, 77 400 T
I wonder how many of those broke off in the door lock?
Old May 14, 2004 | 08:56 PM
92TRANSAMWS6's Avatar
Well, it has a piece of metal in it to keep that from happening. Still it doesn't look very strong, wouldn't wanna use it too often.
Old May 19, 2004 | 01:26 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
... why not just have a copy made?
Old May 19, 2004 | 11:54 PM
VERTIGO Z28's Avatar
Car: FBODYS
Engine: ALWAYS 8'S
Transmission: ALWAYS MENTAL
Axle/Gears: RUSTY AND BRAND NEW
That is an ignition key. They usually came with two keys on one card i.e. door & ign. I can still get them but their made out of something other than plastic. Domestic versions are getting hard to find.
Old May 20, 2004 | 12:05 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
If it is for the car listed in his sig, that would not be the ignition key unless it was used as a template to have another key made from it. Even then he would have to know the code value for the pellet in the key (VATS).
Old May 20, 2004 | 12:25 AM
Car: FBODYS
Engine: ALWAYS 8'S
Our machine plugs in the ign and tells us the proper resistance of the chip. All the temp key is for is to give us the factory cuts w/out requesting the codes from GM.
VATS is almost 15 years old. Most of our competitors even have the reader to determine what blank to use. $3500 start up cost pays for itself fast at $75 per key made.
