Did GM Performance Parts ever off the 1LE brakes as a "kit"
Old Sep 16, 2004 | 11:36 PM
Mark_ZZ3's Avatar
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
I don't have any performance parts catalogs from that long ago. Jut curious if GM ever offered a 1LE brake kit over the counter? I suspect they did ... just looking for more info.
Mark.
Old Sep 17, 2004 | 02:27 PM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
Axle/Gears: BW 9-bolt w/3.73
Nope, never did it as a "kit". Stainless Steel Brake Company offers a bolt-on 1LE kit using mostly OEM components for about $995.00 but GM never offered it whole.
Old Sep 18, 2004 | 09:42 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
You could buy either front left or right side complete assemblies over the counter at any chevy dealer.Before they were discontiniued from G.M.You could also get them from the G.M. performance parts catalog.i think they were about $565 ea.side.
Old Sep 18, 2004 | 11:36 PM
Mark_ZZ3's Avatar
Engine: TPI(s)
I found three old Performance Parts Catalogs, but no luck
- 1992 ... no brakes, but it did have all the SLP f-body parts. Runners, cold air kits, proms, etc.
- 1997 ... did have the Dana 44
- 1998 ... only had parts for the discontinued Dana44.
Looks like I need to find a 93 or 94 version of the performance parts book.
Mark.
Old Sep 19, 2004 | 10:28 AM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
That's a new one on me. I don't remember any kits being available at all from GM, only the individual parts all of which are still available except for the prop-valve, saddle brackets, and spindles.
Old Sep 19, 2004 | 11:26 AM
cdartz's Avatar
For the amount of money it would cost to cobble together a 1LE front setup it would just be easier to get a system from Baer. That's what I did for the rear on my RS, and eventually will do on the front too. Some will argue that if you look hard enough you can do it cheaper, but the Baer stuff is basically an even better setup so I went that route.
Old Sep 19, 2004 | 12:28 PM
Mark_ZZ3's Avatar
Engine: TPI(s)
Agreed. You can most likely get better parts for the same or better pricing.
I am trying to put my car back to 100% stock as it has some collector value (in my opinion). It might cost me more, but in the end, it should make a better car ... historically speaking that is.
Mark.
Old Sep 19, 2004 | 01:41 PM
Mark_ZZ3's Avatar
Engine: TPI(s)
Any chance you would know the part number, or have a parts catalog?
Old May 20, 2016 | 09:55 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Did GM Performance Parts ever off the 1LE brakes as a "kit"
I know this is a old post but kind of wondering if a part number was found for the whole 1LE setup or if that was only offered to the racers.
Old May 20, 2016 | 10:30 AM
Mark_ZZ3's Avatar
Engine: TPI(s)
I recall back in the early 90's that GM did list it in the performance parts catalog along with the newly announce ZZ1 engine! I can't find that parts book which I find odd since I keep all that stuff.
And to give more credit to this story ... years ago I bought a set of 1LE brakes complete from a GM "cut away" car. IT was used to showcase all the performance parts you could buy from GM. So the brakes were all detailed and painted. They were installed on a 1987 IROC.
But maybe people had to order the parts separate?
Mark.
Old May 20, 2016 | 11:52 AM
TTOP350's Avatar
I'll check and see if I have those parts books
Old Jun 8, 2016 | 06:20 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Funny, I don't ever remember replying to this or receiving notifications.Anyway, these are the part #s i recall, 18018571 & 18018572.I don't remember which is RH, LH.I recall reading a car mag article & also from a Camaro book i have, somewhere.Only one of them listed the price.Hope this helps.
I'm sure some of you can do better research than me.
Old Jun 12, 2016 | 01:59 AM
jlarsson's Avatar
Car: 1989 TTA
Engine: 3.8L Turbo V6 - VIN 7
Transmission: 200R4
Mark.
Anyone figured out (or got a copy) which year they did list the 1LE parts in the GM Performance Parts Catalog ... been looking as well but not sure which year they where in there so any help much appreciated.
Old Jun 14, 2016 | 10:40 AM
Manic Z's Avatar
Car: 1985 Camaro IROC-Z
Transmission: GForce T-5
Axle/Gears: 10 bolt 3.73 posi
Here's a scan from my 1993 GMPP catalog....
Old Jun 14, 2016 | 12:27 PM
TTOP350's Avatar
I think I saw that in my 92 book as well, will try an remember to look tonight
Old Jun 14, 2016 | 01:22 PM
Mark_ZZ3's Avatar
Engine: TPI(s)
Thats awesome! I knew I saw it back then, but can't find that book.
The part numbers are great ... confirms the 1LE package to so speak:
- Usual "brakes" we all talk about
- also includes 36mm front and 24mm rear sway bar
- Front struts, rear shocks
- springs
I can confirm I've seen all these parts in a 89 1LE (non-R7U car). Even down to the part numbers on the springs.
The only R7U thing they did was to put the wonder-bar onto the Trans Am.
Mark.
Old Jun 14, 2016 | 03:44 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
I at least now know, that I don't have to remove my lower control arms and replace them with 16" wheel specific ones. I'll just remove the (lower control arm bumpers part #14089443) off the used 16" control arms I got off on Ebay and install them on my originally installed lower control arms.
Old Jun 14, 2016 | 10:55 PM
Drew's Avatar
- springs
Mark.
Not necessarily. Read the page again... It says -
The following components are required when converting a base Camaro or Firebird to the superior handling of the 1LE option.
The key word is "base". Most of the part numbers in that list are common equipment. If you're starting with a 1982 Sport Coupe or maybe a V6 than yeah, all that stuff is necessary. If you've got a 85-92 Z28 or WS6 Firebird, you've probably already got nearly everything in that list aside from the front brakes, rear control arm bushings, and shocks/struts. Everything else is the same as the stock hardware used in most 16" wheel equipped 91-92 cars. Some things like the CDB/NNL springs are typical FE2 hardware that date back to the early 80s.
Originally Posted by MY87LT
I at least now know, that I don't have to remove my lower control arms and replace them with 16" wheel specific ones. I'll just remove the (steering bumpers part #14089443) off the used 16" control arms I got off on Ebay and install them on my originally installed lower control arms.
The bump stops might matter, IDK - but the more important part is probably the 16" wheel stops to keep 245/50's from ripping out the fender liners.
Old Jun 15, 2016 | 10:59 AM
MY87LT's Avatar
Car: 1987 Camaro LT
I meant to say "lower control arm bumper" is what GM listed on the catalog so as not to rub the inner fender well.
Old Jun 15, 2016 | 02:39 PM
Drew's Avatar
Google the part number, it's for the front bump stops. The part that controls how far the wheels can turn is the steel bracket that keeps the spindles from turning too far. Pretty sure it's riveted to the control arm.
Old Jun 15, 2016 | 05:11 PM
MY87LT's Avatar
Car: 1987 Camaro LT
They are riveted and have long been discontinued. I searched all over the net.
Old Jun 16, 2016 | 09:11 AM
jlarsson's Avatar
Car: 1989 TTA
Transmission: 200R4
Many thanks for sharing, much appreciated !!
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
gta90
Sep 15, 2015 04:00 PM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
