Door Decals
Old Oct 6, 2004 | 08:06 PM
cdiedrick's Avatar
Car: 89 IROC
Door Decals
I have an 89 IROC that I just had repainted. The decals are on the center of the bottom half of the door, which I said is wrong. Since I had the decals made for $30 I was not going to argue with the man, but I know it isn't right. Does anyone know the exact place that the decals are suppossed to be located at?
Chris
Old Oct 7, 2004 | 08:28 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I from 85-87 they were located forward on the door, 88-90 they were on the rear of the door (if equiped)
Old Oct 9, 2004 | 10:44 AM
gscz28's Avatar
Car: 89 iroc
Engine: 355 TPI FINALLY
Transmission: 700r4/ SHIFT KIT
here's my 89 IROC
Old Oct 11, 2004 | 05:01 PM
cdiedrick's Avatar
Car: 89 IROC
Thanks for the response guys. I knew that I was right on that one. But does anyone know the exact measurements from the edge of the rear of the door, and also from the bottom of the door that I can go off of? That would help so I can place them in the correct spot.
Chris Diedrick
Old Oct 12, 2004 | 08:28 AM
gscz28's Avatar
Car: 89 iroc
I'll get some when I get back home later tonight.....
Old Oct 13, 2004 | 06:03 PM
gscz28's Avatar
Car: 89 iroc
here are the dims of the decals
from the edge of door to the bottom of the I is 3 1/4
bottom of the door to the bottom of decal is 6 1/4
and the decal is 2 1/4 X 25 1/4
not sure if this will work...
Old Oct 14, 2004 | 06:48 PM
cdiedrick's Avatar
Car: 89 IROC
Thanks again for the info, that is a start, I guess my only other question is how far from the edge of the door is the I in IROC. As in from the quarter panel edge of the door. That is the only other thing that I need to know in order to get my decals in the correct location.
Chris Diedrick
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
86IROC112
Oct 9, 2015 10:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
