87 Z28 ?'s
Old Dec 14, 2004 | 10:15 PM
custom88camaro's Avatar
Car: 88 camaro
Engine: carby 350
Transmission: t-5 from v6 car
87 Z28 ?'s
Great news... A friend of mine just informed me about an 87 z28 that is supposed to have a good T-5 in it. I am going to look at it on Saturday. I initially just wanted the transmission, but when I found out it was a Z28, (not sure, he is pretty sure it is), I got kinda excited. Could I expect a 5.7 TPI????? Should I expect the larger diameter sway bars???? What about posi rear end???? I am busting right now, because I can get the whole car for $100!!!!!!!
I don't know a lot about it, but I am pretty sure it doesn't run, and I was told the body was pretty rough. I am sure it is if the guy only wants 100 for it.
Please let me know if this is cause for real excitement. Thanks
Old Dec 14, 2004 | 11:34 PM
Car: 88 camaro
Engine: carby 350
Come on guys, pleeeeeez let me know what to expect. I am dying here.
nick418's Avatar
Engine: L98, Hemi 6.2
Re: 87 Z28 ?'s
is it a IROC Z28? I dont think it has a 350 TPI in it, cuz you mention a T 5 (theres no 350s with 5 speed, Unless he did a swap...) If the 8th digit in the VIN says "8" then its a 350.. Its good chance its a 305 LB9 with 3.08 gears, maybe... Goodluck and tell us all about it. If its just a Z28 then it has to be a LB9, and there was no 350s im 87 with the Z28, only the IROC Z
Old Dec 14, 2004 | 11:39 PM
Car: 88 camaro
Engine: carby 350
Not sure whether it is IROC or not. I hope it is, cuz then it should have the big sway bars, right?? I forgot about GM being retarded and not giving us a 5 speed manual 350 tpi. That would have been awesome. Is it likely however, that it will be a TPI? I don't know all of the RPO's by heart yet. LB9 ??????
Old Dec 14, 2004 | 11:44 PM
nick418's Avatar
If its just a plain Z28 then it can either have a Lb9 305 tuned Port Injection or a Carb LG4.... Thats stock atleast.. Who knows what this car has, get the VIN and decode it here at TGO or ask the owner as well and the RPOs get them... But if the car was totally swapped (engine/tranny), then the vin and RPO is really not gonna make a big diffrence.. that T5 means theres a good chance with no 350
Old Dec 14, 2004 | 11:50 PM
Car: 88 camaro
Engine: carby 350
The car is only 100 dollars, so I am going to buy it unless the clutch won't release, and the trans won't shift into all 5 gears. ****, I might buy it even if it doesn't shift. It is only 100 dollars.
Old Dec 14, 2004 | 11:57 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Read the Tech Data people, it's there for a reason.
https://www.thirdgen.org/tech/techdb.shtml
Old Dec 15, 2004 | 12:16 AM
Car: 88 camaro
Engine: carby 350
OOPS........Thanks. How would I know if my Dad's 86 IROC had the available 350 TPI?
Lemme try to guess, but I would like an answer anyway.
Find L98 code somewhere on RPO tag.
Q. Where is RPO Tag?
Q. Where on tag is engine RPO?
Sorry about these stupid Q's, I am only recently learning the RPO's and their meaning.
Old Dec 15, 2004 | 12:35 AM
Administrator
It didn't have it.
https://www.thirdgen.org/techbb2/sho...hreadid=233781
Old Dec 15, 2004 | 12:51 AM
Car: 88 camaro
Engine: carby 350
What about the sway bars. Is the large diameter sway bar only going to be on the car if it is IROC, or does the Z28 give up the large bar by itself?
Old Dec 15, 2004 | 01:59 AM
Administrator
The IROC-Z got all the best stuff. From the Tech Data.....
"The new IROC-Z option was available on the Z28 and came with new 16x8 aluminum rims, P245/50VR-16 Z Rated Goodyear Gatorback tires, fog lights, CAMARO on front license plate panel, .5 inch lowered ride height, body colored valances, Delco-Bilstein rear gas shocks, special front struts, increased spring rates, special jounce bumpers, 5 degrees of caster (up from 3.5 on Z28) in front wheel alignment, `WonderBar' front frame rail stiffener, special valving in steering for increased steering effort, larger rear stabilizer bar with stiffer bushings, IROC-Z exterior decals and interior dash badge, and a thinner two-color lower body stripe."
Old Dec 15, 2004 | 09:02 AM
camaro430sut's Avatar
Car: 89 Camaro/ 02 GC Overland
Engine: 355 V8/ 4.7 HO V8
Transmission: T5/ 545RE
Axle/Gears: 10 Bolt 3.73/ Dana 30, Dana 44 3.73
cant it also have a L03. wasnt that the base motor for z/28 and iroc. i could be wrong.
Old Dec 15, 2004 | 09:09 AM
cdartz's Avatar
No, the L03 wasn't available until 1988.
Old Dec 15, 2004 | 12:06 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
LO3 replaced the LG4 in 1988 as the base engine.
John
Old Dec 16, 2004 | 07:22 AM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
The Z28 and IROC-Z both used identical sway bars. The IROC-Z added the Wonderbar.
Old Dec 16, 2004 | 07:30 AM
Administrator
Check your e-mail Willie....
I've always read IROC-Z's had a 1mm bigger sway bars and with better bushings.
Old Dec 16, 2004 | 03:49 PM
Krazzycowgirl's Avatar
Car: 87 Irocz, 95 Z28, 71 Z28 /RS
Engine: 355 Tpi, LT1, 355
Transmission: Auto, Auto, 4sp
THe RPO codes should be in the center box if its a L98 car you should also see B2L.
B2L: PERFORMANCE PACKAGE & ENGINE PACKAGE V8 5.7LPFI
L98 : 5.7 LITER V8 TPI ENGINE
As someone else said check the vin tag its in the winsheld drivers side next to the dash. check for the 8th digit
S= V6 TBI LB8 2.8 L
F= 305 V8 TPI LB9 5.0 L
H= 305 V8 BC LG4 5.0 L
8= 350 V8 TPI BL2 5.7 L (or LB9)
Old Dec 16, 2004 | 06:12 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
S= V6 TBI LB8 2.8 L
It's already been determined that it isn't a 350 because of the 5 speed. This information is useless at this point.
Old Dec 16, 2004 | 07:51 PM
The Tranny may be a transplant he didnt say if he knew or not.
Old Dec 16, 2004 | 08:57 PM
Car: 88 camaro
Engine: carby 350
Thanks for all the replies, guys and gals. I really know nothing about the car except that it has a manual transmission and it is a v8 car. The guy who told me about it said he thinks it is an 87 Z28. I will know for sure on Saturday when I go to look at it. I really want the biggest factory sway bars I can get, N/S about the mm.......anybody know?????
What I would like to know now is if the Z28 tags got you the large sways, or if the biggest bar came with the IROC-Z tag.
Right now I am hoping it is an IROC-Z, because I want the big swaybars. My car is/was an RS model factory 6 cylinder, and the sways arent very big.
Can't remember right now...... When did the T-5's go WC???
Old Dec 16, 2004 | 09:32 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
if you realy want big sway bars why not just go to spohns and get new ones?
a z28 for 100 i would grab it and do a rebuild on it if the body is solid.
if it is a tpi and the body is junk you can get up toward 400 for the tpi with computer, very hot for street rods. If you polish it up real nice ive seen 800 if done right. pleanty of usable parts if the body is bad. sounds like you got a good find if the car is some what complete and not totaled.
let us know what it is when you get it.
Jeff
Old Dec 16, 2004 | 09:41 PM
Car: 88 camaro
Engine: carby 350
Jeff
I never checked it out because I knew eventually I would find some used ones. Honestly, I don't even know how much they run? Maybe I will look into it if this car doesn't have the big bars.
BTW, How big are the BIG bars?
Old Dec 17, 2004 | 06:25 AM
okfoz's Avatar
not sure on the exact size, but I belive the Pontiac WS6 sway bars are even larger than the IROC, and even some of the aftermarket "High performance" ones .
John
Old Dec 17, 2004 | 03:13 PM
Car: 88 camaro
Engine: carby 350
If it is a plain old Z28 I hope Willie is right, but I really hope it is an IROC Z. I would like to have that Wonderbar.
How good are the factory Wonderbars??
Old Dec 19, 2004 | 03:10 AM
Car: 88 camaro
Engine: carby 350
No Such Luck!!!
GRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR
I went and looked at the car today, MAJOR disappointment. The 87 z28 with T-5 I had been dreaming about was crushed by an 83 Berlinetta with no engine, and somebody's cobble job TH350.
The sway's are same or smaller than mine, no GFX, no TPI anything, no smile on my face at the end of the day.
You couldn't pay me $100 to haul this POS away. It was laying on the ground, no tires or wheels, supported by the gay *** lake pipes cleverly bolted to the rocker panels. It had a custom "brushed" look to the paint.......I am guessing that paint was originally intended for somebody's barn or something.
Basically, I am crushed, please pity me.
Old Dec 19, 2004 | 04:05 PM
labrat's Avatar
Car: 87 IROC-Z
Transmission: automatic
I feel your pain!
Old Dec 19, 2004 | 04:59 PM
nick418's Avatar
that sucks man.. **** happens... I mean keep searchin and dont give up
Old Dec 28, 2004 | 08:39 PM
REALPOWER's Avatar
Car: 1984 Camaro on steroids/ 1987 iroc-z28 5 speed.
Engine: 383 nitrous motor / poindexter 305
Transmission: Th350
Whats the difference between
-Iroc-z
-Z28
-Iroc-z28
I own an 87 IROC-28 with an LB9 5-speed. Its pretty quick (for a 305)
starliner
Feb 9, 2016 08:18 PM
blackz281le
Jan 11, 2016 07:51 AM
David Frans
Oct 31, 2015 08:12 PM
Night rider327
Oct 9, 2015 09:25 AM
z28joe2
Sep 28, 2015 05:54 PM
