True I.R.O.C. specs used during races 80's
Old Feb 28, 2005 | 09:01 PM
redline724's Avatar
Car: 86 iroc
Transmission: 400
Hey I was searching online for the true specs to the camaro that served in the 1980's International Race of Champions. I do not intend to find the specs for factory irocs, i know them already. Anyone know the specs (goodyear tires, titanium intake, etc) of the true irocs used during the races? I know they were all the same for each year, maybe they were different.
Does someone have the specs to at least one of the years?
Old Feb 28, 2005 | 09:57 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Theres a few guys here who have orignal Players race cars. If you looked up their threads about their cars, you could find their contact info. I'm sure they'd be happy to help.
Old Mar 1, 2005 | 08:03 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I am not sure, but from the pictures I have seen there is no resemblance to the factory version and the race version of the IROC cars.
Although they look like a Camaro, I think the similarities end there. I may be mistaken, but I think there a full roll cage car with a shell that resembles a stock car, kind of like NASCAR. since 1982 or abouts, NASCAR Winston / Busch / Nextel / ARCA series' have little or nothing to do with a "Stock Car" etc.
since were on the subject, Are they still running Firebirds?
Players cars on the other hand, were kind of like the firehawk series here in the states. They used Stock Firebird chasis and put in a roll cage, They were 1LE cars, but I think even the engines were basically a stock engine, with probably tighter tolerances than the run of the mill factory Engine.
I WILL ADMIT I AM NOT AN EXPERT, but from what I ahve seen here on the boards, and talking to people that seems to be the case.
John
Old Mar 1, 2005 | 08:24 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You are correct. They were typical tube-chassis race cars of the day, with enough of the Camaro sheet metal grafted on over the tubing to where it looked "stock" from 100 feet away. Just like most any "stock car".
I don't know offhand what the motor specs were; but, given the tracks and so forth, I'd expect they were similar if not identical to the Winston Cup cars of the day, with a wheelbase and track width appropriate to the Camaro instead of the Monet Carlo they were running in Cup those years. Which would have been 358 CID, single 4-barrel, flat-tappet cam. Jerico 4-speed. F*rd 9" rear.
The intake most certainly wasn't titanium. Probably a Victor. IIRC the tire sponsor was in fact Goodyear. In those days they were still running bias ply tires.
You might be able to get more info directly from IROC at www.irocracing.com maybe even a copy of the spec they would have supplied to race car builders.
Old Mar 1, 2005 | 09:34 AM
Mr. TurboTA's Avatar
Yes,
They are still running the Firebirds at IROC! Only thing is, nowhere on the car, does it say Firebird or Trans Am.
Kinda funny! Racing cars that are long gone!
George
Old Mar 1, 2005 | 10:22 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Well it certainly wouldn't say Trans Am; that being the trade name of a competing racing series. You can believe that.
As far as I can recall, those cars have never been badged with the mfr name or model; not when they were Porsches, or Camaros, or those stupid Dodge POSs, or Firebirds.
Old Mar 2, 2005 | 04:08 PM
CDN_87IROC's Avatar
1984/85 IROC Z28 Race car
Price est $65K
Powertrain:
SOHC V-8, 350 cu in
Power SAE net 450 bhp @ 6500 rpm
Super T10 4-speed manual transmission
Chassis:
Banjo Matthews independent front and solid axle rear suspension
Recirculating-ball steering
Hurst 12.0-in vented front and rear brakes
28x10x15 Goodyear Eagle IROC radial tires (road coarse)
27.5x9.5x15 Goodyear Eagke IROC radial tires (superspeedway)
Measurements:
Wheelbase 105.0 in
Curb Weight 3350 lb
Fuel Capacity 33.0 gal
Derek Bell
Old Mar 2, 2005 | 10:35 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
SOHC? not SOHV?
Old Mar 3, 2005 | 11:37 AM
CDN_87IROC's Avatar
Single Over Head Cam (SOHC)
Old Mar 3, 2005 | 12:08 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They weren't single overhead cam. They were small block Chevy motors. Cam in block.
Old Mar 3, 2005 | 02:17 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Ditto. My friend's Nissan has a SOHC
Old Mar 3, 2005 | 02:20 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Ummm, yeah...
I know I'm an idiot and a moron, but do a little thought experiment right quick. You've got a V8 motor, 350 CID. Where the hell are you going to put a single overhead cam and have it work the valves on all 8 cylinders? Now granted I'm pretty stupid and all, but I sure can't think of a way that would work.
So I suspect that "SOHC" business must be a typo on somebody's part somewhere.
Old Mar 3, 2005 | 04:15 PM
CDN_87IROC's Avatar
I was only quoting racer Derek Bell (raced IROC series 84&85). I stand corrected on Single Over Head Cam.
Any guess what he meant by SOHC?
okfoz
Oct 13, 2015 02:19 PM
91 SrS
Oct 7, 2015 04:32 PM
mfp189
Sep 27, 2015 09:25 AM
JSDaddy189
Sep 26, 2015 03:50 PM
wstephan96
Sep 25, 2015 04:28 PM
