What is this ONE RPO code??
Old Mar 31, 2005 | 04:33 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Ok, below are my RPO codes. What is that one I'm missing??
16A : STRIPE COLOR, ACCENT, TWO TONE, BLACK/GARNET RED
19Q : MOLDING COLOR (BLACK)
1SA : OPTION GROUP 1 (1988) N33, AO1, CD4 (NON-GT)
41U : PRIMARY COLOR, EXTERIOR, BLACK
6ZW : SPRING, COMPUTER SELECTED, FRONT, LEFT HAND
729 : SEAT BELT COLOR, DK CARMINE (9) (91)
72B : TRIM COMBINATION, CLOTH, DK CARMINE (B)
72I : INTERIOR TRIM, DK CARMINE (91)
72W : TRIM COMBINATION, VINYL, DK CARMINE (W)
89A : STRIPE COLOR, ACCENT, TWO TONE, RED/LT GRAY (91)
8NL : COMPUTER SELECTED REAR LEFTHAND SPRING
9NL : COMPUTER SELECTED REAR RIGHTHAND SPRING
A01 : WINDOW, TINTED, ALL SHADED, W/S
AR9 : SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
B3E : NOISE CONTROL
B6R : RED IROC-Z ROCKER AND BUMPER EMBLEMS
B84 : ORNAMENTATION, EXTR MLDG, B0DY SIDE
C49 : DEFOGGER, RR WINDOW, ELECTRIC
C60 : HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
D34 : MIRROR, VISOR VANITY
D35 : MIRROR, OUTSIDE REAR VIEW
D72 :
D80 : SPOILER, RR END PNL
D88 : DECAL, STRIPE, SPORT
E5Z : SPEEDOMETER ADAPTER (DELETE)
E72 : BODY LENGTH, INCR I8 INCH
E9Z : SPEEDOMETER KEY (DELETE)
FE2 : SUSPENSION SYSTEM, RIDE HANDLING
G80 : AXLE POSITRACTION, LIMITED SLIP
GU4 : AXLE REAR, 3.08 RATIO
J50 : BRAKE SYSTEM, POWERD72
K68 : GENERATOR,105 AMP
LB9 : ENGINE, GAS, 8 CYL, 5.0L, TPI, HO
M39 : TRANSMISSION, MAN 5 SPD B0RG WARNER, 77MM, 2.95
MM5 : MERCHANDISED TRANS, MAN 5 SPD PROVISIONS
N65 : WHEEL & TIRE,SPARE, SPACE SAVER, STEEL
N90 : WHEEL, 15 X 7, ALUMINUM CAST, 4.75 INCH BOLT CIRCLE
NA5 : EMISSION SYSTEM, FEDERAL, TIER O
NP5 : STEERING WHEEL, LEATHER WRAPPED
PB4 : LOCK CONTROL, WHEEL
QYZ : TIRE ALL, P215/65R15/N BL R/PE ST TL HWY
T93 : LAMP, TAIL & STOP, SPECIAL
T96 : LAMP, FOG
U79 : SPEAKER SYSTEM, 4, DUAL FRT COAX, DUAL EXT RGE PKG
UM6 : RADIO, AM/FM STEREO, SEEK/SCAN, AUTO REV CASS
UQ1 : RADIO PROVISIONS, FOR STEREO
V73 : ANTENNA, FIXED
VAN : ASSEMBLY PLANT, VAN NUYS, CA
W62 : ORNAMENTATION, AERO PACKAGE
WW4 : APPEARANCE PACKAGE, AERO #4
Z28 : MERCHANDISED PKG, SPECIAL PERFORMANCE
Old Mar 31, 2005 | 06:12 PM
3rdgenstm's Avatar
Car: ‘92 Z28
It is probably D7Z, which is a gear driven speedo. Double check-- many of the letters and numbers look the same at first glance.
Old Mar 31, 2005 | 09:34 PM
zbugman's Avatar
Car: 1987 Firebird converted to 91/92 Trans AM appearance.
Engine: 2.8 v6 w/ injector, throttle body, intake mods
Transmission: automatic soon to be swapped out for a T5
Same with one of your other codes...your E72 is actually E7Z. There was no body extension on our cars.
Old Mar 31, 2005 | 09:49 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
hahaha never thought of that! What would E7Z be then?
Old Mar 31, 2005 | 09:58 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Nevermind, I found it on this site:
http://tech.firebirdv6.com/generalspecs.html
They have EVERY RPO code!
Old Apr 1, 2005 | 07:13 PM
GTA Jim's Avatar
Car: 1990 GTA
Engine: 5.7
Transmission: 4L60
Axle/Gears: 3.27 Posi
Yes.. Very good site.. But I've found that NO site has EVERY RPO code.. (I have no idea why).. I'd love to see a site that has them all.
Perhaps they generated a random non-existant RPO code and stuck it on every 9999th vehicle that came down the assembly line just to drive people crazy
This site is missing some common ones, (Like the engine code L98 - for the popular 5.7L TPI V8)
Old Apr 2, 2005 | 07:34 AM
seanjnl1's Avatar
Car: 91 Camaro RS
Engine: 305 V8
Transmission: 4-speed auto
My car is listing an RPO code of R6V, which according to that site is:
R6V SLP FIREHAWK (1995)
Which is kind of amazing since my car is a 91 Camaro RS.
Old Apr 2, 2005 | 07:48 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Well, I know they recycle RPOs, and that site seems to be aimed towards Firebirds... not sure what years though!
Possibly you have the ULTRA rare 3rd gen 4th gen!
Old Apr 9, 2006 | 02:34 PM
camarosource's Avatar
Car: Custom 1992 Camaro Z28 25th Anniver
Engine: 5.7L V8 350 L98 TPI
Obviously didn't check ours ;-)
D72 - Outside door handles : Black
Old Apr 11, 2006 | 11:04 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Wow, old thread! Thanks for the info... though the next can of soda you buy might have traces of those door handles
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
