"non" pull down hatch mechanism?
Car: 1981 Chevy Malibu, 1987 Formula 350
Engine: 229 V6, L98 TPI 350
Transmission: TH350, 700R4
Axle/Gears: 10 bolt ???, 9 bolt 3.27 posi
While at the junkyard yesterday I saw 2 camaros both of which had inteesting hatch latches.....instead of the big ol' pull down thing that i absoloutly HATE, it was just a simple latch and then the lock thing....
Is this "normal" for earlier camaros/firebirds? are they any good? Thanks
schweet!
If I wasn't already broke from buying the 87 Trans Am to part out, i'd say i'd go pick one up as well as the A/C delete heater box today.....
buutttttt, looks like i'll be going friday to get one :-)
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
FYI, the brackets that the latch bolts to on the body are different on non-pull down and pull down latches. You'll need to drill out the spot welds and transfer the brackets to do a swap.
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
The only pull down mechanisms that might work with the non-pull down mech is possibly the late 1991-1992 style. They were smaller and I believe they used the same bolt pattern as the pre 1987 non-pulldown style.
John
John
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
Axle/Gears: 4.10 gears
i think you could get the pull down in 85. i know mine doesnt have it because it was an early one and ordered . But im pretty sure you could get it in 85 but the early ones didnt get it .
Car: 1992 B4C 1LE
Originally posted by Dave84Bird
I am getting all the manual stuff including the mounting bracket and etc... off a 85 donar car.
was there a year that pull down and non pull down were both offered where the non pull down cars might have a plate that can be used in conversion?
Car: 92 Camaro
Why convert it? My pull down quit working so I just adjusted it down to where latched correctly and sealed good, however the inside power release doesn't work that way, but I don't mind using the key.
Car: 88 IROC
Transmission: 5 speed
Axle/Gears: G92
The 88 I recently acquired doesn't seem to have a pull down feature, but does have the console release switch. I haven't removed the back panel, but it doesn't have any big lump to conceal a pull down.
Curiosity got the best of me today and I removed the rear panel and guess what ?? I do have a pull down latch. Someone had removed the electric plug to the motor. I plugged it in and all it does is run constantly. It appears the worm gears are worn out. Something else to add to the grocery list of parts needed.
