T-5 option codes
Old May 18, 2005 | 08:45 AM
redliterunner's Avatar
Car: 89 IROC convert.
Engine: tpi 305
Axle/Gears: 3.42 10 bolt
T-5 option codes
I was looking at 1989 option codes on the web and saw three different option codes for the T-5: MB1, MK6, M39, as well as another option, MM5, which does not specify a trans type beyond manual.
Can anyone tell me what this is all about? I expected one code for manual and one for auto.
Old May 18, 2005 | 10:35 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I know at the very least, that there's 6-cyl T-5s, TBI T-5s, and TPI T-5s in that year, with different gear ratios.
I suspect that's at least part of why they're like that..... 3 different part #s on the Bill Of Materials for the transmission in the different cars.
Old May 18, 2005 | 11:33 AM
chuck88iroc's Avatar
Car: 1988 IROC-Z Convertible
Engine: 305 LB9
Transmission: MK6 5-speed
Axle/Gears: G80, G92, GM3
My understanding is the MM5 code simply means the car came provisioned for a 5 speed manual transmission. The other codes you should find will tell you what type. My car has the MK6 which translates to Manual 5 speed, Borg Warner, 2.95 1st, O/D.
Chuck
Old May 18, 2005 | 11:49 AM
Engine: tpi 305
Well, it didn't take long to make sense out of this issue. Thanks.
Old May 18, 2005 | 01:33 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
There are 2 different transmissions with the 2.95 (V8) 1st gear in that year; the TBI cars came with a .63 OD, and the TPI cars, or at least some of them, came with a .73. 2 different codes for those.
Old May 18, 2005 | 03:24 PM
kaotik's Avatar
Car: 1991 Camaro Z28 Clone
Engine: 350 w/TBI
Transmission: WC T-5
Axle/Gears: Spicer 3:73 Auburn Posi
Is there any way to tell which one you have or any specifics once the tranny is out, and you dont know what it came from other than a 3rd gen?
thanks
Old May 18, 2005 | 03:31 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
http://www.5speeds.com/t5/index.html
BumpaD82
Feb 26, 2016 02:57 PM
Zane Story
Oct 8, 2015 12:40 PM
64Chief
Sep 12, 2015 08:05 AM
DARKmj16
Sep 9, 2015 04:07 PM
Formula_88AE
Sep 3, 2015 01:47 PM
