striker bolt
Car: 91 Formula, 95 GT
Engine: 5.7, 5.0
Transmission: T5, T5
Axle/Gears: 3.42:1, ???
striker bolt
does anyone have the GM part number for the door striker bolt? I need these but I don't want to pay $40 from TDS for 2 bolts + 2 washers. thanks.
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
82-92
20464563 - Striker
4469196 - Washer Steel
20053174 Washer Poly
20464563 - Striker
Engine: 5.7, 5.0
okfoz, GM Parts Direct does not recognize the steel washer part # you gave me. but I think I am just going to reuse the ones I have and just replace the striker bolts because their toast, and I can't find decent ones at the yard. Thanks again.
It is JUST a washer, I would think any good hardware should have them close, take your original. Or try a place that sell only Nuts and Bolts, we have several here in my area.
If you re-use then your offset should be correct as well, even tho that is usually not an issue.
John
John
Numbah-1
Sep 12, 2015 08:57 PM
Saxondale
Exterior Parts Wanted
Sep 7, 2015 06:11 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
