Rear end I shouldnt have
Old Oct 11, 2005 | 06:45 PM
Matthew91-Z28's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
OK....Just am finguring this out today when I replaced my axle seals and bearings:
I have a 1991 camaro Convertible Z28 that should have:
28 spline axles
2.73 rear
posi rear
This is what I found:
Axle tube (1st 3 letters): 6HT which should be a 88 or 89 with a 2.73 posi
26 spline axles
3.42
0pen rear
And too make it more confusing, on the top of the carrier above where the gear oil drain plug is I have a little plastic fitting that I can pull out reavealing a little port in the top. I have no idea what the little plastic port is for. I almost think it might be an ABS sensor port.......
What the hell???
Old Oct 12, 2005 | 05:26 AM
R1UK's Avatar
Car: Was 3rd Gen now MustangGT
Engine: 302
Axle/Gears: 3:73:1
That little plastic "top hat" on mine is the breather hole.
Old Oct 12, 2005 | 10:11 AM
Sounds to me like your car's rear has been swapped out at some time or other.
Pretty common actually.
No point in getting all worked up over how it "should" have this or that. The car has what it has now. Period. Buy stuff that fits it now that you know what it is.
This is why all of that "codes" BS is just that.... BS. People change stuff out. NEVER EVER buy parts for something like that, until you place your eyeball upon the parts in question and verify what they are. Especially when you know perfectly well, as you obviously do, that there's a possibility for variation.
Old Oct 12, 2005 | 10:20 AM
Yeah....I was just freaked out yesterday. I'd been under the car all day in the rain....replacing bearings/seals when I noticed I lost a side gear shim in the diff. I just wanted to get the correct parts and finish.....
Actually I think its cool that I have 3.42 rear. Good to know when I buy a posi unit for a 3-series carrier.
Old Oct 12, 2005 | 10:24 AM
I gotta agree!!
That's a WHOLE LOT BETTER than your "codes" telling you it's 3.42, but finding 2.73s.
Sux that it's 26-spline instead of 28 though. Oh well.
Old Oct 25, 2005 | 11:14 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
haha someone lucked out! BTW, have any pics of your car? I'm a sucker for the 'verts
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
