I need help decodeing my firebird???
Old Oct 26, 2005 | 08:15 PM
jcurrieirocz's Avatar
Car: '81 Trans Am
Engine: 6.6L
Transmission: auto 350
Hi,
im having conflicting info on my car,,, it musta been in an accedent heres what i know!!
The body was orig. black,,, the vin on the dash tells me 1G2AX8711CNS0222(X)
and the id tag under the hood says:
D 14C 2FS87N225174
178 19L 19U55ME
AR9 CC1
WS4 080
103170 264030
where else can i find id tags build info or anything on the car....
my hood is off another car im sure its a flat hood. The fenders have vents and i have a wing....whats up with that if i have a S/E as my vin says???
Old Oct 27, 2005 | 07:44 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Whats your problem?
D 14C 2FS87N225174 - THe last 5 numbers here should match the last 5 numbers of your VIN.
All Firebirds started out as a 2FS87 from 82-84 From there they got the W for Trans AM and X for S/E The VIN you posted does not look right, or you left something out.
John
Old Oct 27, 2005 | 05:41 PM
Car: '81 Trans Am
Engine: 6.6L
Your right and the vin doesnt match the id tag under the hood?? I know this but where else can i find info on the car?? Where are the build sheets? Are there any vin tags on the car??
well from what i see the vin shows its a 82 s/e that had a v6 now the car has a v8 and the tag on the rad support says its a 83 plain firebird.... so im thinking the car was in a wreck or something messed up..... but what if the vin tag was changed what other info on the car could tell me the truth??? the doors are no help as i just changed them and got rid of the old ones.
Old Oct 27, 2005 | 10:58 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
The VIN sez Firebird S/E and the "Fisher Body tag" sez Trans Am(WS4 = T/A)
On 2nd-gens the VIN sequenced number and the Fisher Body tag VIN sequence numbers do NOT match on cars produced at the Norwood, OH factory. I don't know if this holds true for 3rd-gens. Maybe somebody can answer that.
GM commonly put a "hidden partial VIN" stamped on the firewall behind the heater box. This should match the VIN on the dash.
What is the partial VIN on the engine block? Its on the passenger side block deck surface. Behind the alternator. You should also find one on the transmission.
What color is the interior? On '82 T/As the lower half of the dash and console are dark charcoal regardless of interior color. On base Firebirds and S/Es it was color matched to the interior. This will obviously not mean anything if your car has a dark charcoal interior as all Firebirds have the charcoal lower halves with that interior color.
FYI, '82 T/As with the LG4 carb'ed engine came with the flat hood as standard. The power bulge hood was optional and there was a shortage which left the Crossfire and Recaro T/As with priority.
I found the build sheet for my '84 T/A under one of the rear seat cushions. I've seen them in the front seat springs, under carpet, door panels, dash pads, and above headliners and gas tanks. Keep in mind that it was optional for the line worker to hide the build sheet inside the car. Many were used as coasters for soft drinks while working on the assembly line or just simply thrown out.
Old Oct 29, 2005 | 05:19 PM
Car: '81 Trans Am
Engine: 6.6L
well what else would a real ta have??? maybe my car is an se and got hit in the front farly bad that they put on a 83 t/a fenders and rad support,,, i dont really feel like takeing the dash apart to check for a vin....and the trany and engine vin wont help at all as im sure the car off the line had a v6(ocording to the vin) and now it has a carbed lg4 305. Maybe the 305 was also from the 83 ta?? wierd. heres a pic of my firebirds int. it looks light grey (like the seats) color to me. Some of the inter tho i have replaced so if theres anything that catches your eye on what year or what model of firebird it is let me know what you see.
Old Nov 13, 2005 | 01:47 PM
82DAYTONA's Avatar
Engine: 305 TBI
Transmission: auto
hi i am new here
good day all i am new to this site and hope to get my car decoded for me?
if thats what it is called?
the plate under the hood reads 4 lines of #'s
as follows?
C 08D 2FS87L 566727
18D 75L 75U W
AR9 CC1
D B S 244154
i have read up on some info on the web and did notice this is the first year of new body style and was used for the daytona pace car in 1982 it was also red as is mine
i think it has the WS7 package due to the drum brakes in the rear
came that way due to the 52,000+ made with 4 wheel disk for 10 days they did the WS7 package
i bought this car on ebay and wonder what i should do with this?
it has 97,000 miles seems to run ok as i can burry the speedo in no time flat (85 mph speedometor) it has the black "PMD" seats and the guy gave me the gold turbocast rims?
any info about this car would be helpfull
thanks much and have a good day
tom
Old Nov 19, 2005 | 07:51 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
i beg to differ on the 82 trans am stuff,
my 82 regular trans am (LG4 4bbl 305 with thm200 and 2.73 8.5")
has the factory steel non functional power bulge hood
and all of dash and console is black, no gray anywhere
the date stamp on the hood is same as on fenders, the date code stamping code deal on them
also last part of body tag matches last part of vin code
jut like it should
interesting.,.,
Old Nov 19, 2005 | 10:02 PM
Dens71TA's Avatar
my 82 regular trans am (LG4 4bbl 305 with thm200 and 2.73 8.5")has the factory steel non functional power bulge hood
Yeah, so your's has the optional power bulge hood on a LG4. Thats exactly what I said. Flat hood standard, power bulge optional.
Then something has been changed. The lower half of '82 T/As were dark charcoal regardless of interior color. No ifs, ands, or buts.
Old Nov 19, 2005 | 10:12 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
wow i see that pic with the gray and wow nope mine is totally black where all the gray parts are in that pic
and i cant recall ever seeing gray parts in interior of any third gen actually
hmm..
i didnt realize on the hood thing i was saying exact same thing ill hae to re-read that one
lol
thanks
Old Nov 19, 2005 | 10:28 PM
Dens71TA's Avatar
The picture in this thread isn't of a dark charcoal. The dark charcoal is almost black. Its not even hardly noticeable until you try to swap a part onto a '83 or '84 which is black.
The pic above is pebble gray or some name to that extent. Color matched lower dash and console bottoms were used on base and S/E Firebird.
Old Nov 20, 2005 | 07:36 AM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
oh.
hmmm
i dont know then
mine looks all black
so who knows.
Old Nov 21, 2005 | 07:50 AM
okfoz's Avatar
Was this true with 83 as well...
Actually I thought all Trans Ams got the black dash without exception and the SE, Base and Formula got color coded dash pieces from 82-87...
John
Old Nov 21, 2005 | 10:49 AM
Car: '81 Trans Am
Engine: 6.6L
where do i find this date???
Old Nov 21, 2005 | 12:16 PM
okfoz's Avatar
The Hood is in plain view, like the rear hatch.
The Doors its in the jamb
The front fenders it in front of the wheel wells inside the fender... have to remove the battery sometimes to see
THe rear quarters is behind the wheel well and behind the spare tire, so that needs to be removed and the drivers side is behind the compartment...
There should also be some on the bumper supports too...
they only used them for a few years, I think they stoped in 1990 or 1991.
John
Old Nov 21, 2005 | 01:54 PM
okfoz's Avatar
giggle...
I was thinking the VIN tag...
The date stamp is on the underside of the hoods usually towards the front on the passenger side.
Keep in mind that the date is not the same as the Assembly date... Our cars were made in Assembly plants, NOTHING was made there everything came from outside and the cars were assembled there.
John
Old May 1, 2006 | 10:52 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
either way though the 82 t/a lg4 cars got the power bulge hood, no matter what
i see that your car is an early produciont, its got the buttons in the door panels to cover where manual crank sjhafts would be, unlike mine that doesnt have them and was built 08E
5th week of august and is the 67676th one
good luck
jtwoods4
Sep 3, 2015 05:39 PM
jtwoods4
Sep 3, 2015 10:19 AM
90formulaVortec
Sep 3, 2015 09:26 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
