89 Gta
Old Nov 4, 2005 | 12:28 AM
89GTA2LV's Avatar
Car: 89 Trans AM GTA
Engine: 5.7L
89 Gta
I just bought a 89 GTA with 59K miles all original.
I am going to list the option codes. Any of them rare?
AAA
AM9
AQ9
AU3
A31
A90
BC8
BV3
B2L
B20
B67
B84
CC1
C49
C60
DC4
DE4
DG7
D3Y
D42
D81
D9B
E5Z
E9Z
FE2
GW6
G80
IL2
JG1
J65
KC4
K34
K68
L98
MD8
MXO
NA5
NK4
GW6
N64
PW7
QLC
R6A
TR9
T93
T96
UB3
UF6
UK3
UC1
UT1
UT4
U25
U29
U62
U75
VAN
VG8
VK3
V73
WS4
WS6
WW1
W62
YA7
YF5
Y84
1SZ
11Q
4OU
52P
6ZX
661
662
669
7ZX
8NL
9N7
END
Old Nov 4, 2005 | 06:06 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
There's not really "rare" options on a GTA since they had just about everything you could get on one.
Old Nov 4, 2005 | 07:21 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
You have T-top 350 car GTA, not particularly rare for 1989, but unusual for the entire run from 87-92...
John
Old Nov 4, 2005 | 07:43 AM
FrankieRider2's Avatar
Car: '88 Bright Red GTA UPC 81U
Engine: 5.7L TPI
Axle/Gears: 3.27:1
John
John is correct. While unusual as a whole from 1987-1992, the 1989 model year seems to be the year that sees the most 350 cars with T-tops.
Although cars slipped through in 1987, 1988, and early 1991.... the 1989 and 1990 model years are the only ones that specifically have the "350 restriction" for the T-top option removed on the order sheet. With the 1990 production being basically a half/year run, you don't see too many of those these days....
Congrats on a nice car.
Old Nov 4, 2005 | 07:07 PM
89GTA2LV's Avatar
Engine: 5.7L
You know my option codes doesn't have the g90 option but I have the 10 bolt rear end...
Old Nov 4, 2005 | 07:44 PM
Klortho's Avatar
Car: 1987 GTA
If you are referring to the G92, Pontiac didn't use that code, Okfoz explains this in this thread
https://www.thirdgen.org/techbb2/sho...hreadid=329702
Plus, you might want to check again, if you have the 3.27 like you stated on your other thread....that's the 9 bolt Borg Warner rear which was in the 87-89 GTA's. If not, the rear has been changed out.
Old Nov 6, 2005 | 01:08 AM
GTA Jim's Avatar
Car: 1990 GTA
Engine: 5.7
Transmission: 4L60
Axle/Gears: 3.27 Posi
Yes.. Might be worth checking.. The GW6 is the Borg Warner 9 bolt (3:27 ratio).. GU5 is the standard GM 10 bolt (3:23 ratio)..
F-body-fan
Jan 12, 2023 01:49 PM
sheachopper
Jul 31, 2019 11:27 AM
2012sergen11
Oct 13, 2015 07:38 PM
bjpotter
Oct 4, 2015 07:48 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
