'77 350 motor?
Old Nov 28, 2005 | 06:53 PM
91WhiteCamaro's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
'77 350 motor?
ok, i just recently found my engine code located on the passenger side in front of my valve cover. the number is V0404CLD. im not sure if they are zeros or o's, but all the sites i look at say the last 3 numbers/letters tell you what it is. well when i looked it up it says its a 1977 350 vette engine. that HAS to be wrong, because i don't think that adds up at all... can someone help me out with this dilemma?! im so confused.
Old Nov 28, 2005 | 06:54 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
What side of the block is the dipstick on? Its very likely it was swapped out at some point.
Old Nov 28, 2005 | 06:59 PM
Car: 1991 Camaro RS
Engine: 305 TBI
left side. and thats another thing, my friends dad has a 1990 T/A GTA with an L98, and our engines look alot alike. is it possible, someone just changed the block and kept everything on top? im clueless when it comes to what fits, im new to it all. also, i got my car 2 months ago, and i kno for a fact its been in a wreck, because my front end is off alignment slightly. also, all of my wires and things are slapped on really sloppy, i had to unplug so many things and hold back so much stuff just to get a toothbrush over the numbers to scrape the crap off.
Old Nov 28, 2005 | 07:21 PM
Car: 1991 Camaro RS
Engine: 305 TBI
i think i posted this in the wrong forum section. sorry.
Old Nov 29, 2005 | 01:17 AM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
So it looks like this (ignore the supercharger):
Or this:
The first one is a TPI motor, the second is a TBI motor. Yours would have had a 305 TBI stock. There's also a label either on the inside of your hood or on the top of the radiator. It'll contain information about your emissions and it should list the engine size.
If those numbers are right it's possible it was swapped out.
Old Nov 29, 2005 | 10:18 AM
Car: 1991 Camaro RS
Engine: 305 TBI
it's an LO3. 305 TBI. i kno that, but iwas just wandering what that number meant
Old Nov 29, 2005 | 12:08 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
The number in front of the valve cover is frequently changed to sell the car with a better motor than it really has. Trust me, I bought a 74' Nova with a '65 Vette motor in it, but the rear codes said 69 2bbl 4 door 350.
You need to get the numbers on the back of the block.
Old Nov 30, 2005 | 12:22 AM
911rsq's Avatar
Car: '91 Z28 & '90 RS Vert & '89 RS
Engine: 5.7L & none & 2.8L (soon to be LSX)
Transmission: yes
Axle/Gears: One's with teeeeefs
Wow...u got stung by a SCAM ARTIST, cause that's a lot of work to mill those numbers off and stamp new ones back on there, especially for a '74 NOVA.....
Old Nov 30, 2005 | 08:40 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Not really, just file them off and use a number punch with a hammer.
Old Nov 30, 2005 | 08:28 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
1973 CLD 350 tur hydro 400 T L82 250 4 Vette
1977 CLD 350 m/t, high altitude X L82 210 4 Vette
the heads/intake and whatever can be anything by now
can swap 55-95 stuff on the block just fine
so it can look like any engine really except that the oil stick is on driver side through 79 and pass side 80 and up
good luck
theshackle
Sep 17, 2020 08:26 AM
theshackle
Mar 5, 2017 06:37 PM
Mickeyruder
Sep 2, 2015 02:45 PM
Out-Cast
Aug 17, 2015 10:57 AM
st.evel07
Aug 13, 2015 06:15 PM
