Where to find build sheet?
Old Dec 16, 2005 | 07:21 PM
BLURR's Avatar
Car: 1989 Iroc Z
Engine: 5.7 TPI
I just purchased an all original 60,000 mile 1989 Iroc Z with a 350 T.P.I. Red on Red car with no t-tops.
My question is, Where did the assembly plant hide the build sheets in these cars? Where will I most likely find it. Im not talking about the sticker in the console with all the codes.
Im talking about the piece of paper that told the workers what went on each car and where the car was to be shipped and such. You know how on 2nd gen F-bodies they are usually behind the back seat back, under the front seat or on top of the fuel tank.
Any help would be appreciated.
Old Dec 16, 2005 | 07:42 PM
91rsowner4life's Avatar
Car: 1997 S10
Engine: 4-Cyl 2.2 Liter
Transmission: Automatic
well from what i have read on this site it may be under the carpet on the passangers side or on top of the fule tank and some have been found inside the passangers door or under the back seat bottom
Old Dec 17, 2005 | 03:58 AM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
The infomation on build sheets used in later 3rd-gens isn't nearly as complete as the earlier cars. I have always found a copy in each of the front seat bottom cushion springs on 87-up cars.
Old Dec 17, 2005 | 08:43 AM
H0TR0Dn's Avatar
Car: 88 Formula 350
So if you take your seat out you can see it?
Old Dec 17, 2005 | 10:33 AM
BLURR's Avatar
Car: 1989 Iroc Z
Engine: 5.7 TPI
Thanks for the info guys.
If anybody else has any ideas, please do post them up.
Old Dec 17, 2005 | 11:24 AM
TTA 1387's Avatar
Car: 89 20th Ann. TA
Engine: Turbo 3.8 V6
Transmission: 200 4R
Mine was glued to the panel that covered the spare/jack. Pretty mangled but I was able to salvage the part that said "Turbo GTA"
Old Dec 17, 2005 | 09:06 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Been covered dozens of times. Do a search.
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
Clean87TA
Sep 4, 2015 11:23 PM
Reborn756
Sep 4, 2015 03:42 AM
sreZ28
Aug 14, 2015 07:48 PM
