Replacing front windshield (need Help)
Old Dec 15, 2000 | 11:19 AM
biscwgn's Avatar
Hey i'm going to have my front windshield replaced just wanting feedback car is 18K mile show car it got air or water between glass around bottom of windshield and fogged up. Wandering do they make exact oringnal front windshields or just aftermaket? also what should i watch for when they replace it the do's and don't i want it done right??
Old Dec 15, 2000 | 12:48 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
You can go to GM and pay 300% more than aftermarket, but there's still really no guarantee that you'll get one that looks 100% original. I replaced the windshield in both my IROC and my Sport Coupe with a PPG windshield. PPG is one of the original GM glass suppliers, and other than a couple digits in the corner, it appeared to be 100% identical. Nobody's going to know the difference, and if for some reason you find a show that checks for 100% concours cars and goes through the pains to inspect everything that critically, I'm guessing that the glass will be the least of your concerns.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Dec 15, 2000 | 12:50 PM
Jim85IROC's Avatar
Oh, and if the windshield is just leaking, you may not need to replace it. A little black silicone sealer around the windshield and a new trim ring and you'll be good as new. I'm guessing that it's not leaking though. If you run a hose all the way around it, you'll get drips inside if it's leaking. They don't usually leak on the bottom, and even if they did, I don't think you'd get moisture inside. It sounds to me like you've got a different problem causing the moisture.
The IROC Homepage
Old Dec 15, 2000 | 01:53 PM
biscwgn's Avatar
So you think a autoglass company would be a good choice?????
Old Dec 15, 2000 | 09:31 PM
David M's Avatar
Car: '84 Z28
Engine: L69
Yes an autoglass company would be your best bet. I recently had my windshield replaced on my '84 for $175.00 and the glass company came out to my workplace and did it in the parking lot. They did a good job and it does not leak. You will though need to replace the outer windshield molding. Hope this helps.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
TheExaminer
Aug 26, 2015 04:59 PM
TheExaminer
Aug 25, 2015 07:34 PM
