car restoration
car restoration
I have a 1984 TA l69. I'm looking to do some restoration to it including the interior, engine rebuilds, exhaust mods, etc. The exterior is in great shape, but I dont know exactly what to ask for in terms of an engine rebuild. I want great performance (0-60 in six seconds or less), and also something that's going to be a daily driver. Also I've seen cyberdyne digital gauges, I like how they look, do they have a complete six gauge kit or individual gauges for sale for my dash? Please help me where to start to all this, for I'm a little new to the auto thing. Thanks very much. '84 Ta h.o t-5
A friend of mine is currently rebuilding his 84 T/A-it was a L69 car but the motor locked up after 200,000+ miles.
So now we are gonna put in a zz4 Crate motor somewhere in hte neighborhood of 450 H.P. and he is currently changing his interior over to black-(was light grey almost white)
he also installed a roll cage and subframe connectors it's a t-top car
Dave
93 CAMARO-(FOR SALE) 3.4 v6,5spd,borla cat back,hurst short throw shifter,moroso cold air induction kit,kyb adjustable shocks,17" wheels,275/40zr17 comp t/a's
84 FIREBIRD-2.8 V6,5spd super economy model
no options except t-tops( not even locking),no tilt,no cruise,no delay wipers,no rear defroter,no a/c,no rear spoiler(i put one on)no pw,pdl,pm,pseat,no gauges(just a 85 mph speedo with no trip odometer and a big f***in' gas gauge)
90 FORMULA 350-
Edelbrock t.e.s,gutted cat,Borla cat-back,LT4 hot cam ,24# injectors,holley h.p. fuel pump,K&N Throttle Body mounted air filter,52mm throttle body,accel 8.8mm wires,plugs cap and rotor,ADS superchip,GTA tailights,T-tops
No E.T's yet.
Previous 3rd gen's
83 Trans-Am 305 CFI auto T-TOP
84 Firebird 305 H.O. auto HARDTOP
87 Firebird 2.8 V-6 auto HARDTOP
Dave
90 FORMULA 350-
No E.T's yet.
Previous 3rd gen's
Car: Trans Am
Welcome 84taho,
When I bought my car 10 years ago, I wanted to know the same thing as you, where to start, but there were no message boards back then so I learned the hard (expensive) way. So I am going to give you the best advice that I have learned over the years.
First, based on what you have described, you are looking to rebuild/modify your car not restore. Restoring means to bring it back the exact or close to the way it left the factory.
Okay, with that in mind, you have to ask yourself what do you want to do with the car.
Do you want to drag race? Autocross? Show car? retain value (lol)?
Each requires a different setup for optimum performance or different requirements.
Next, I would work on the car using a systems approach. You have suspension, brakes, interior, engine, exterior are some "systems". Pick one and work on one system at a time. For example, if you choose "suspension", do your whole suspension, bushings all around, rear lower control arms, panhard bar, subframe connectors, shocks/struts and strut tower brace. When your done, then move to "brakes" or whatever.
Finally have patience. Nothing will work exactly the way you want to, Yes you will make mistakes that will cost you, and you will curse, bleed and sweat, but damn, owning a third gen is awesome and fun, and 10 years later, it still isn't finished, it never will be.
As for the Cyberdyne dash. No they don't make it for the Trans Am, they do make it for the camaro. Yes, you could buy the individual gauges, but you would have to make a custom dash to mount them. Search the "electronics" forum for more info on hooking up electrical gauges.
Good Luck
1983 T/A LG4 w/T-tops
Rebuilt/Modified E Q-jet
Custom Dual Ram-Air
Self painted cherry red w/ restored black/grey interior
Welded Comp Eng SFC
Tokico Struts/Shocks
Hotchkis LCAs and Panhard Bar
Energy Suspension bushings all around
Good Luck
Custom Dual Ram-Air
Welded Comp Eng SFC
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
Linson
Aug 21, 2015 02:12 PM
ElPaleterro85
Aug 13, 2015 03:49 PM
