build sheet from 89 IROC
Car: 1989 Iroc rebuild
Engine: 355 carb'd
Transmission: 5spd
Axle/Gears: 3:08 pos for a while
how much information am I missing from this build sheet,the lower left corner looks as if it burnt??or did the kids Dr.Pepper spill years ago do this???it was very brittle and tore some
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
I have two from 1988 Player's cars. The lower left only has a "rear seats" section that is two lines lower than the AR9. On mine it just say "rear seats".
The bottom of the middle section just says Z28 in the second from the bottom.
The lower right has nothing more that what you see. My 1988 has the word "RACE" on the lower right.
Just curious ... where did you find this? Under or in which seat?
Mark.
Mark.
Engine: 355 carb'd
Transmission: 5spd
under
passenger seat,the passenger side was hit real hard so the insurance company totaled it,i bought it back from ins. and since and a rollback deliver it to the yard,jtmiller sold me a lower control arm,torque arm and e-brake cable,i can drive it,but it's needing alot of work
Car: 1987 IROC-Z
Engine: 5.7L V8
Transmission: TH700R4
Axle/Gears: 3.73 Borg Warner
Dude, happened there? Although if you're going to get T-boned, that's the side to get hit on. You going to pull the drivetrain out of it?
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
ouch.. that looks like it hurt..
so you found that under the passenger seat?? like flip the seat upside down and look at the foam? I'd like to find mine.. what year was that car?
Engine: 355 carb'd
Transmission: 5spd
the wrecked one
is an '89 IROC,after getting it where i could drive it,i needed to get the seat out because the quarter is pushed in enuf to squish the seat,i pulled the door armrest and pulled the seat to keep it from having the indentation from the interior trim become permanent,still not decided to fix the body or retro fit the engine/drivetrain into my 69
mustangman65_79
Aug 11, 2015 03:17 PM
