storage compartment panel
Old Aug 21, 2005 | 06:41 PM
blue_tacos's Avatar
Car: 82 Berlinetta 87 Iroc
Engine: 327
Did lots of Camaros come with the panel that goes over the storage comparment or was this uncommon? Thanks
Old Aug 22, 2005 | 12:38 AM
MikeDirntRulez's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI (L03)
Transmission: 700R4 (MD8)
Axle/Gears: 2.73 Open (GU2)
They were pretty common, however there were two types:
The not so rare, cloth type one. I don't know the material, but it feels like cloth or polyester or something.
Then they had the vinyl/pleather ones. Those ones were more rare than the "cloth" ones.
EDIT: wait, I reread your post and I don't think you are talking about the privacy shade. If you are talking about the cargo cover that was carpeted, yes it was uncommon, but not really rare. Somebody can correct me, but I thought they only came on BOSE equipped cars, not sure on that one though.
Old Aug 22, 2005 | 01:09 AM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Transmission: Tremic6060
Axle/Gears: good enough
i got that cover, the one that covers up the little well at the tail end of the hatch, and im for dang sure i dont have the bose speakers
Old Aug 22, 2005 | 07:31 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Most of them were not for the bose cars. However I have seen more on Camaros than Firebirds. I think it was an option on any of the Camaro line, I have an SC with it, and I have 1 or 2 other panels I have snagged from junkyard cars. As I think about it, I do not remember seeing any Firebirds with the option. not saying they do not exist.
The BOSE units did use the panel however and the panel will be there if you have BOSE. the panel holds the rearmost pair of speekers for BOSE systems. (again, Bose was a Camaro only option)
Its kind of a neat option IMHO, but its kind of inconvenient in some ways because storing things in the back is a slightly more of a hassle. I like the shade better, just because its more convenient.
John
Old Nov 10, 2005 | 07:11 PM
badbob66's Avatar
Car: 86 trans am
Engine: carbed 305
Transmission: auto
Axle/Gears: 9 bolt disc posi
John
I found a rear panel at a wrecking yard,it was in a 85 trans am.
Of course it wont fit my Camaro,it hits the back panel,The trans am did not have the pull down motor for the hatch like my camaro so it has a thinner back panel.
badbob
Old Nov 11, 2005 | 04:21 PM
okfoz's Avatar
Actually in 1987 the hatch pulldown was standard, and all of them after 1987 should work properly, the only year that may not is the 91 & 92 when they changed the rear hatch release pulldown unit, it was much smaller and I am not sure if they changed the rear trim piece.
ALSO apparently those cars that were equiped with the rear windshield wiper might have the larger bump as they needed the extra contacts like on the 87-90 cars...
John
Old Dec 28, 2005 | 05:05 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
I have the vinyl/pleather roll up privacy shade and I have a question if anyone knows. My shade will not rool up unless I do it manualy. I took it off and one of the end plastic caps is broken where it mounts to the gear I guess is what I call it. Has anyone been able to either repair this, taken it apart, or is it what it is?
Old Dec 28, 2005 | 05:41 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
This is the part being asked about. Obviously, the woofers are not OEM. Yes, it was an option on non-Bose equipped cars. Although it 's not very common, I would not go as far as to say it's "rare".
Attached Thumbnails storage compartment panel-locking-rear-storage-cover.jpg
Old Dec 29, 2005 | 03:03 AM
2BlackZ28s81&83's Avatar
Car: 1981 & 1983 Camaro Z28
Engine: 81 - 350 (ZZ4 355hp) 83 - 305 LG4
Transmission: auto - 81 - 350 Turbo / 83 - MX4
My 83 is equipped with this option. While not exactly a "rare" option it was only installed in a small percentage of cars each year it was available. Example in 1983 it was installed in only 7% (6.7 exact) of all Camaros produced that year.
It is actually RPO Code B48 Deluxe Luggage Compartment Trim.
Cost 164.00 and was a factory only installed option.
Production Numbers by Year (Camaro) unfortunately I don't have these numbers for the Firebirds
1982 - 23,641
1983 - 22,992
1984 - 38,827
1985 - 18,418
1986 - 29,738
1987 - 25,943
1988 - 16,185
1989 - 23,150
1990 - n/a
1991 - n/a
1992 - n/a
I have pictures of them bone stock open and closed if you want them
Old Dec 29, 2005 | 12:38 PM
AmorgetRS's Avatar
My 84 Firebird had the cover. Non-Bose, non motorized pull down. It was one of the few options it had.
Old Dec 29, 2005 | 01:38 PM
okfoz's Avatar
On a totally related but unrelated note: Could you get both the shade and the compartment cover on ONE car?
I have never seen that,
I wonder if thats why they droped the cover after 1989, they just went to the pull shade.
John
Old Dec 29, 2005 | 01:55 PM
90tararebird's Avatar
Car: 1990 trans am
Engine: 350 tpi
hey duke if you take apart the shade roller you should be able to rewind the spring that makes it retract. If you take it apart you should be able to figure it out. Can't remember exactly how it goes but it was pretty simple. Fixed it in like ten minutes.
Old Dec 29, 2005 | 03:00 PM
okfoz's Avatar
The spring will only retract if you have the ends pushed in IIRC.
JOhn
Old Dec 29, 2005 | 05:43 PM
MNformula350's Avatar
My 83 Trans Am had both the shade and hardcover.
Old Dec 29, 2005 | 06:51 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
To me it seems the roller is a complete assembly like a solid state piece of electronics equipment. I epoxyed the piece that was broken but it still will not retract on its own.
Old Dec 29, 2005 | 06:53 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
JOhn
Thanks again John,
But it doesn't seem to want to retract on its own. I fixed the broken end it and installed it and I still had to roll it up manually?
Old Dec 29, 2005 | 07:02 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
That looks cool,
There is one of those in my local yard but the carpet is tan and no keys or else I would have grabbed it.
Old Dec 29, 2005 | 07:12 PM
my82roc's Avatar
Car: 89 Iroc Convertible
John
In my 88 Sport Coupe I have both the roll up shade and locking hard hatch cover.I bought the car from the original owner who had ordered the car from the dealer.I also have the dealer invoice for the car with both items on there so I know that they are original.It really does seem kinda strange to have both of these options as they serve mostly the same purpose
Old Dec 29, 2005 | 09:34 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
you know what i think my 82 trans am has a carpeted panel
its dark blue interior
if it does then its stashed somewhere because i have the rear carpet and stuff out of the car currently, along with console and some other parts of the car, stashed away
never seen a shade in one of these cars i dont believe
anyone got a pic ?
hmm
Old Dec 30, 2005 | 07:42 AM
okfoz's Avatar
THats good (interesting) but good to know that you could indeed get both.
John
Old Dec 30, 2005 | 12:31 PM
Car: 1990 trans am
Engine: 350 tpi
Duke maybe my 90 was different but the ends would come off and then you could rewind the spring that is inside the tube and press the ends back on. Like i said it could be different on newer models.
Old Dec 30, 2005 | 12:39 PM
okfoz's Avatar
I think All I did was wrap it up while it was off, then when I put it on the car it would retract, because the ends were pushed in.
Its been a while but IIRC thats how I fixed one of mine.
John
Old Dec 30, 2005 | 07:03 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Thanks for all the help guys, I have taken it off wound it up and it still will not retract. Also the ends wont come off unless I break them and epoxy them back together. I have one last question, can someone post a pic of the rear cargo panel where the shade clips into. The one I have looks like there was a new panel put in and the holes were just cut out. Have a great new year.
Old Jan 7, 2006 | 01:33 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Another question about the carpeted cover. Does anyone know if my car was not equiped with one and I snag one from the JY, will I be able to install it in car car no problem? I mean will it just bolt up or will I have to modify, weld, drill to get the hinges to attach? One more thing, it is in a Bird and I have an Iroc but I am pretty sure the trunk size is the same. Thanks
Old Jan 8, 2006 | 03:02 AM
If it was originally equipped it should just bolt right up
Old Jan 8, 2006 | 01:26 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Originally posted by 82 Iron Duke
Another question about the carpeted cover. Does anyone know if my car was not equiped with one and I snag one from the JY, will I be able to install it in car car no problem? Thanks
If your car didn't originally have the "storage well cover" you'll need to remove the brackets from the donor car and weld/screw them onto your car. There are a set of brackets with studs on the floor pan that the hinge attaches to and there is another set of brackets on the tail panel for the lock striker. You'll also need to swap the rear plastic trim piece as those are different.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Falcon50
Aug 22, 2020 03:26 PM
kkirch15
Sep 30, 2015 04:44 PM
drumstixer
Sep 29, 2015 03:02 PM
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
