Convertible Top Squeaks.....Help!!!!
Old May 14, 2001 | 12:42 PM
zedder 1 9 9 0's Avatar
Car: 1990 Iroc Z Convertible
Engine: LB9
Okay, I know I am the proud owner of a notoriously flexible car that is famous for squeaks and rattles. However I have one squeak that is driving me insane.Let me start off by saying that I have only had the car on the road for a week. I have noticed a very loud squeak comming from the passenger side Lockdown when the roof is up. I have checked everything I could see as far as fasteners are concerned and they are all tight. I have noticed that the pass side lock is very easy to latch compared to the drivers side that has some resistance. Has anyone had/have this problem and could ayone think of a possible cure?I guess I could just turn up the radio but its the crappy OEM radio with the original "tired" speakers that distort very easily, almost as bad as the squeak .
1990 Iroc convertible,305 tpi,Black with black leather interior,lowered
Old May 14, 2001 | 10:21 PM
scanman717's Avatar
Car: 92 Z/28 Convertible
Engine: LB9
Transmission: Mad Dog Auto 700R4
This may sound strange, but check your Passwnger Visor. I just replaced the hinge on mine and noticed that the original one had some black, foamy stuff on it.. After a couple of day I now know what it was for... It was rubbing the metal above the hinge, so I stuck a small peice of weatherstripping. Problem solved...
Troy
92 Camaro Z28 Convertible
3" Flowmaster
Ported Plenum
Old May 16, 2001 | 07:20 AM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
If I remember you can put shims under the latch/handle assembly, thus allowing a tighter grip when the top is up and latch engaged.
Rob P
89RSconvtZZ4TPI
Edelbrock Hi-Flow Intake
SLP Dual Cold Air Intake
1 5/8" Headers
Semi-Siamesed Runners
MSD6AL/relocated MAT/ AdjFPR/IROC frnt@rear swaybar/wonderbar/steeringbox/alum drvshaft/ Alston SFC/3:23posi disc rear/MAC LCA/H.Adams Panhard Rod/KYB struts/ shocks/
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
1992 Trans Am
May 10, 2023 07:19 PM
69 Six Pack
Oct 5, 2015 07:51 PM
yankeecarman
Convertibles
Aug 23, 2015 07:47 AM
Dan Hubbard
Aug 12, 2015 09:05 PM
