Do we have anyone on the board that owns an 1989 1LE car?
Old Feb 14, 2006 | 09:39 PM
Mark_ZZ3's Avatar
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
Just curious if we do. I need to compare notes on car specs.
I've searched the archives, but no luck tracking anyone down.
Mark.
Old Feb 15, 2006 | 12:56 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
My TTA is a 1LE car :-)
Dont think its what your looking for however :-)
I'll ask around in my area, but I dont believe so or I would prolly know about it already.
later
Jeremy
Old Feb 15, 2006 | 07:32 PM
Mark_ZZ3's Avatar
Engine: TPI(s)
Hmm, your car might help actually. Do you mind crawling under the car (actually turn the wheels one way) and check out the part number on the front struts? Being a 3.8L, the struts should be different than a 1LE V8 car.
Mark
Old Feb 16, 2006 | 01:22 AM
3.8TransAM's Avatar
I dont know when I can check. Car is in its winter slumber and no way to get under it where its at. I will check it out regardless first chance I get.
later
Jeremy
Old Feb 16, 2006 | 04:51 PM
coolguywalt's Avatar
Car: 89 Turbo Trans Am, '14 Forester XT
Engine: 3.8 Turbo V6
Transmission: 2004-R
If I remember right, the TTA had the WS6 valved struts with V6 springs because of the lighter engine. Where would the part # be anyways? I might be able to check mine out (in the TTA) if they are not that hard to get to.
Old Feb 16, 2006 | 05:27 PM
3.8TransAM's Avatar
Should be a sticker on the strut more towards where it bolts to the spindle.
Least thats where mine are. My car isnt stored at home, so I cant just jump to it lol
later
JEremy
Old Feb 16, 2006 | 07:27 PM
Mark_ZZ3's Avatar
Engine: TPI(s)
If you turn the wheels one way, you can see the lower part of the strut. The part number is about 1" from the bottom of the tube, slightly to the inside of the frame. You might need a mirror to see it. I just stuck my camera in the wheel wheel and snapped a few macro pictures.
Mark.
customblackbird
Aug 15, 2021 10:16 PM
colton_carlson
Mar 8, 2019 12:21 PM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
