What kind of rear end do I have?
Old Jul 29, 2001 | 11:44 PM
maksik7's Avatar
I have a relatively simple question for the experts.
I ahve an 86 TA with disc brakes all around. What kind of rear end do I have stock? Tomorrow its coming off and I'm hoping its a 10-bolt posi with 3.42 or something close? Was that an option in 86?
Thanks for the help.
-Max
86 Trans Am LB9/700R4
-Flowmaster 3inch exhaust, K&N, Ported Plenum, Redone Ignition system
Old Jul 29, 2001 | 11:50 PM
Drew's Avatar
I'm just going to take a stab in the dark and say its a Borg Warner 9 bolt with 2.7? gears or so... maybe 3.27's or 3.45's, but probably 2.7?'s...
Check your RPO sheet if you have one, it'll tell you.
Old Jul 30, 2001 | 12:20 PM
LFN AT U's Avatar
Car: 2004 Chevy Avalanche
Engine: Some that run, some that don't
Transmission: 700R4's, a T-5, and a Turbo 350
I'd guess 9-bolt with either 2.77 or 3.08 gears.
Old Jul 30, 2001 | 04:24 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Can you count to 10? First off get underneath and count the number of bolts in the cover 9 or 10? Common rear end ratios: 10-bolt auto; 2.73 or 3.23. 10-bolt 5 speed; 3.08 or 3.42. 9-bolt auto; 2.77 or 3.27. 9-bolt 5-speed; 3.45. With one wheel jacked up and the car in neutral, count the number of revolutions of the driveshaft relative to one revolution of the wheel. Match it up with the ratios common to either a 9 or 10 bolt. Good luck, Lon.
90 RS Convertible
Owner: Top-Down Solutions
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
Old Jul 30, 2001 | 04:45 PM
Z28DJP1987's Avatar
My answer will be 2:73, possi and be a ten
bolt. Borg-Warner 9 bolts not used in 1986.
Old Jul 30, 2001 | 09:00 PM
maksik7's Avatar
Since I don't have a jack at the moment (left it in my friends car) I will find out the answer tomorrow, the whole rear is getting taken out so I'm going to take a look at the rear while I'm at it.
Old Jul 30, 2001 | 10:45 PM
Tonyrodz's Avatar
Transmission: auto
9 bolts were definitely used in the 86's. My T/A has one and another guy on the board has a 9 bolt in his 86 T/A. mine has the 3.27's and his has the 2.77's-both cars have 4 wheel discs.
Old Jul 31, 2001 | 12:18 AM
Drew's Avatar
"Borg-Warner 9 bolts not used in 1986."
Uh... wrong. 1985 was the first year for the 9 bolt in the Firebird, 1987 was the first year for the 9 bolt in the Camaro.
Old Jul 31, 2001 | 09:38 AM
Z28DJP1987's Avatar
Well I guess that this site and others will have to up date there tech data on when the Borg-Warner 9 bolt was available. I also
find it interesting that no 2:77 & 3:27 ratios were offered in 85 & 86. You may have
them but not from the factory. Quote from the tech data from this site.
Old Jul 31, 2001 | 09:55 AM
Drew's Avatar
Don't believe everything you read in the tech data. The charts are chock full of errors. The history info is much more accurate but not 100%. I wrote almost all of the Firebird history, and added quite a bit to the Camaro history, but there are typos and a few wrong years, etc.
Old Jul 31, 2001 | 09:52 PM
90Form350's Avatar
Both my friends have 86 TA's, both have 9 bolts, one has 2.77s, and the other 3.27s. Don't believe everything you read.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
novaderrik
Aug 10, 2015 12:44 PM
