RPO questions
Old Sep 25, 2001 | 09:15 AM
75/92 Birdman's Avatar
Car: 1998 Trans Am, 1992 Firebird
Engine: 402 LS2 stroker, 355 SBC
Transmission: T56 in both
Axle/Gears: 4.10 gear Moser 9", 3.27 9-bolt
RPO questions
I have a few questions about the RPO codes on my car. This post might be long, so bear with me.
1. I can't decode two of the RPOs - VK8 and 1SZ
2. I have the RPO CC1 for glass t-tops, but mine are Lexan. They are supposedly the original T-tops, is this true?
3. I have the RPO DE4, which is the code for the removable T-top sunshades. I've heard that this is rare, is this true?
4. Why do I have the RPO code U75 for the power antenna and the RPO code V73 for a fixed antenna if my antenna is power?
5. What does the RPO code 1SC(Package Option 03) mean?
6. What are the RPO codes 6XU, 7XU, 8UZ, and 9UZ for? They say SPRING COMPUTER SELECTED and then the location(ie right rear, left rear), but what does that mean?
Can anybody help me out here? Thanks!
1975 Firebird - Pontiac 350, TH350, 27k original miles, rustbucket, ongoing resto project
1992 Firebird - 305 TBI, 700R4, sport appearance package, t-tops, flaming red, 84k miles, soon to be modified
Old Sep 25, 2001 | 09:25 AM
Drew's Avatar
Look around on the internet, use search engines, search this board, etc just type the RPO and search. Usually you can get a good idea.
CC1 only designates TTops, it doesn't distinguish glass or plastic. The glass vs plastic wasn't an option, GM used one or the other depending on when the car was shipped out and if they were replaced under warranty.
No, not really. Almost any later ttop car you check will have the RPO DE4, whats rare is to still have the original inserts in the car.
My best guess is that the power antenna RPO adds to the equipment represented by the fixed RPO.
Its the option level, 1SC would typically mean the car is fully loaded. Check the sales brochure for your year car and it'll tell you what was included.
They're you're coil springs, 6,7 are the front, 8,9 are the rear.
Old Sep 25, 2001 | 09:45 AM
Thanks! I'll search around for those other RPOs. BTW, I do still have the original t-top inserts!
Old Sep 25, 2001 | 03:10 PM
82RECAROTA's Avatar
hectre13
Dec 11, 2023 08:14 AM
Thornburg
Aug 25, 2015 01:46 AM
89redeyeRoc
Car Audio
Aug 24, 2015 07:01 AM
Regal105
Aug 23, 2015 03:45 PM
redmaroz
Aug 16, 2015 11:40 PM
