quick question before i buy this IROC
Old Sep 28, 2001 | 08:09 PM
Psyco50's Avatar
someone is selling an IROC and says that it has a 5.7 that was factory, but put it in after the car
had 100,000 miles. now it has 70,000 on the new engine. and its an Automatic. did a 86 IROC ever
come with a factory 5.7 and Auto?
Old Sep 28, 2001 | 08:28 PM
TAdan's Avatar
Car: 1984 Trans Am
Engine: GMPP 350 V8
No not in 86. The 350 TPI showed up in 87 for production F-bodies. The best motor available in 86 was the 305 TPI. From 87-90 Irocs were available w/ 350's. The motor may just be from another year Iroc. But in 86 no 350's.
Hope that helps.
1983 TransAm
1984 TransAm
1994 TransAm GT
1994 25th TransAm GT
1990 T-Bird SC
1971 Boss 351
Four TransAm's are not enough. Firebirds for all.
Old Sep 29, 2001 | 12:28 AM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Actually there were about 50 or so made in 86 with the 350.... Too bad they were test cars tho that came with the 1LE package if I remember right.
Kat
Old Sep 29, 2001 | 02:19 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
<font face="Verdana, Arial" size="2">Originally posted by Kat:
Kat
</font>
The 1LE didn't come out until '88.
Old Sep 29, 2001 | 06:31 PM
TAdan's Avatar
Car: 1984 Trans Am
Engine: GMPP 350 V8
Somebody's always got to bring out that magic 50 number!j/k
For clarity's sake I chose not to mention those 50 so as not to confuse psycho50.
Old Sep 29, 2001 | 08:31 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
but if it's not the original motor, none of this really matters anyway. As long as they took the proper steps when installing that 350, I'd see no problem. It should have gotten a PROM from an 87 350 Camaro, as well as 24lb/hr injectors.
The problem with a non-original motor is that you never really know what you get. Is it really a 350? There's no way to know unless you run the block numbers or pull a head. Even if it is a 350, it could be a crap $1200 reman with a round camshaft and dinky heads. It's real tough to evaluate a reman motor unless the owner is honest and can present recepits with corresponding technical information.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Sep 29, 2001 | 08:52 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Why would a stock 350 need 24# injectors? All stock 5.7's came with 22# injectors.
Curious as to your thinking.
About the car, unless it's in really good shape I'd pass. Always risky buying someone elses race car, and if it needed a new engine already, it's probably been abused.
Rob P
89RSconvtZZ4TPI Edelbrock Intake
SLP Dual Cold Air Intake 1 5/8" Headers Semi-Siamesed Runners, IROC
suspension, alum shaft. Numerous mods.
92Z28convt5spd (stock)
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Oct 1, 2001 | 06:33 AM
Drew's Avatar
Just so I understand this, you WANT??? a car with 170,000 miles? Why am I thinking that this car probably needs new everything? Its bad enough starting with a car that has 70,000 miles, but 170,000 with a backyard engine swap somewhere in the middle? I'd run far far away from this nightmare, unless its $500 and you have a dependable mode of transpo that you can depend on for a few years while you fix this other car.
Old Oct 1, 2001 | 09:45 AM
Jim85IROC's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Rob P:
</font>
Sorry. I meant 22. My car has 24s due to the cost of 22s as well as my other mods, so I'm just used to spewing info about 24s. Sorry for the confusion.
The IROC Homepage
Old Oct 1, 2001 | 09:44 PM
Rob P's Avatar
Engine: ZZ4TPI
No problem Jim! Just thought I might have missed something.
I think we all agree, step away from this IROC. There are better ones out there.
Rob P
Burnt.Clutch
Camaros Wanted
Aug 21, 2015 11:11 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
mustangman65_79
Aug 11, 2015 03:17 PM
